Hello All,
I have been using FreeCAD in a production environment for about 18 months, with good results and some headaches, mainly due to the topological naming problem.
I am now encountering a repetitive issue when using Sheet Metal, and this is something that I never saw with FC 0.18 and with the development version of FC 0.19.
Let me describe it with a practical example, with Freecad file attached:
1)
I start with a cube, dimensioned as a piece of sheet metal 1.2 mm thick. This is my base sheet metal and I call it "sheet"
2)
Using the Bend function in Sheet Metal Workbench, I design my piece by making 3 bends. I change the orientation of these bends by setting True the attribute "invert".
3)
Now, if I change the thickness of the "sheet", let's say to 1 mm, the orientation of some bends is reversed, so I need to modify the "invert" attributes in order to fix it.
When this happens with larger pieces (with 10+ bends), after I did drawings with Template, the whole file gets corrupted, due to the Topo naming issue... So, basically I need to restart from zero the whole work, and this makes the utilization of FreeCad almost impossible.
Am I the only one to experience this?
Thanks!
gigax
OS: Windows 10 Version 2009
Version: 0.19.24276 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.0
Locale: Italian/Italy (it_IT)
bug report - Sheet Metal Workbench
- test.FCStd
- (19.17 KiB) Downloaded 35 times
Re: bug report - Sheet Metal Workbench
Works correctly for me using the very latest Sheetmetal Wb downloaded today and the following FC version:
OS: Linux Mint 19.3 (X-Cinnamon/cinnamon)
Version: 0.20.25739 (Git)
Hash: 1ceaa09d179832c5fd785ff7e6c24c25ec76ce61
Python version: 3.6.9
Qt version: 5.9.5
Attached my file for you to test, I can change between 1mm thick Extrude to 4mm fine.
Qt version: 5.9.5
- Folded_Cube_SM249.FCStd
- (38.6 KiB) Downloaded 36 times
Hello All,
this bug continues to be a problem for me. Please see the model attached. If I change the thickness of the lamination, some bends are reversed.
As you can imagine, when I do this after creating drawings with Techdraw, all dimensions are corrupted...and I need to restart from zero.
Am I doing something wrong?
Thanks!
Version: 0.19.24267 +99 (Git)
Branch: Branch_0.19.3
Hash: 6530e364184ce05ccff39501e175cf2237e6ee4b
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
Thanks!
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- wrongbend.FCStd
- (61.14 KiB) Downloaded 15 times
If I open test.FCStd and wrongbend.FCStd and just recompute the files some bends already reverse. After correcting them I can change the thickness without issue. Maybe you need to update the SheetMetal WB?
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.3
- test-roy.FCStd
- (22.07 KiB) Downloaded 12 times
- wrongbend-roy.FCStd
- (63.05 KiB) Downloaded 10 times
Thanks Roy,
it's the same for me. If I recompute I get the error once, then it seems to work well.
The problem is that I have several designs done in the last months and often, randomly, when I need to open one and modify something, I get this error, so I need to fix the sequence of bends one by one and after that I need to redo from zero all Techdraw documents as all dimensions are corrupted.
This issue makes Freecad unusable for me, unfortunately. It didn't happen in the past until FC version 0.18... and this makes me think that it can be fixed somehow...
