About how to optimize and improve translation of commands
Founder
Re: About how to optimize and improve translation of commands
Post by wmayer »
See also git commit fe7f4c4be7
If your IDE supports regular expression of the file search you can use
\ssGroup\s+=\s+QT_TR_NOOP
to find the remaining commands (which is 324 atm).
Evgeniy
Post by Evgeniy »
wmayer wrote: Wed Sep 29, 2021 2:34 pm See also git commit fe7f4c4be7
Not bad. I have been analyzing duplicates in Crowdin and "Standard-view" value is repeats many many times.
wmayer wrote: Wed Sep 29, 2021 12:26 pm
sGroup = QT_TRANSLATE_NOOP("Workbench","Something");
in the command classes because as soon as we want to change the context string it needs to be done again for hundreds of classes.
There is a rational grain in this.
Why is this crutch often used in the code:
#if 0 // needed for Qt's lupdate utility
    qApp->translate("Workbench", "Something");
#endif
Why not something like this:
in Command.cpp
... begining
string Sketch_workbench = QT_TRANSLATE_NOOP("Workbench","Sketcher");
... command classes
sGroup = Sketch_workbench
in CommandConstraints.cpp
Will there be a Sketch_workbench variable is visible in other files like: CommandConstraints.cpp, CommandCreateGeo.cpp, CommandSketcherTools.cpp etc. or needs modification of each header file?
It seems better to have one entry point for all values.
And the programmer will clearly know that the string has a translation.
wmayer wrote: Wed Sep 29, 2021 2:34 pm If your IDE supports regular expression of the file search you can use
Im not use IDE yet because I mostly write in Python. I didn 't really dive into C lang
What IDE you are using for C lang developing of FreeCAD?
Evgeniy
Post by Evgeniy »
Updated ts file look better:
  <context>
    <name>Workbench</name>
    <message>
      <location filename="../../Command.cpp" line="142"/>
      <location filename="../../Command.cpp" line="265"/>
      <location filename="../../Command.cpp" line="295"/>
      <location filename="../../Command.cpp" line="339"/>
      <location filename="../../Command.cpp" line="380"/>
      <location filename="../../Command.cpp" line="507"/>
      <location filename="../../Command.cpp" line="679"/>
      <location filename="../../Command.cpp" line="718"/>
      <location filename="../../Command.cpp" line="756"/>
      <location filename="../../Command.cpp" line="863"/>
      <location filename="../../Command.cpp" line="947"/>
      <location filename="../../CommandAlterGeometry.cpp" line="73"/>
      <location filename="../../CommandConstraints.cpp" line="1097"/>
      <location filename="../../CommandConstraints.cpp" line="1335"/>
      <location filename="../../CommandConstraints.cpp" line="1569"/>
      <location filename="../../CommandConstraints.cpp" line="1794"/>
      <location filename="../../CommandConstraints.cpp" line="2108"/>
      <location filename="../../CommandConstraints.cpp" line="2314"/>
      <location filename="../../CommandConstraints.cpp" line="2663"/>
      <location filename="../../CommandConstraints.cpp" line="2911"/>
      <location filename="../../CommandConstraints.cpp" line="3165"/>
      <location filename="../../CommandConstraints.cpp" line="3411"/>
      <location filename="../../CommandConstraints.cpp" line="3561"/>
      <location filename="../../CommandConstraints.cpp" line="4199"/>
      <location filename="../../CommandConstraints.cpp" line="4907"/>
      <location filename="../../CommandConstraints.cpp" line="5209"/>
      <location filename="../../CommandConstraints.cpp" line="5485"/>
      <location filename="../../CommandConstraints.cpp" line="5789"/>
      <location filename="../../CommandConstraints.cpp" line="5933"/>
      <location filename="../../CommandConstraints.cpp" line="6460"/>
      <location filename="../../CommandConstraints.cpp" line="6677"/>
      <location filename="../../CommandConstraints.cpp" line="6977"/>
      <location filename="../../CommandConstraints.cpp" line="7141"/>
      <location filename="../../CommandConstraints.cpp" line="7602"/>
      <location filename="../../CommandConstraints.cpp" line="7729"/>
      <location filename="../../CommandCreateGeo.cpp" line="384"/>
      <location filename="../../CommandCreateGeo.cpp" line="687"/>
      <location filename="../../CommandCreateGeo.cpp" line="728"/>
      <location filename="../../CommandCreateGeo.cpp" line="1052"/>
      <location filename="../../CommandCreateGeo.cpp" line="1095"/>
      <location filename="../../CommandCreateGeo.cpp" line="1850"/>
      <location filename="../../CommandCreateGeo.cpp" line="2093"/>
      <location filename="../../CommandCreateGeo.cpp" line="2362"/>
      <location filename="../../CommandCreateGeo.cpp" line="2389"/>
      <location filename="../../CommandCreateGeo.cpp" line="2623"/>
      <location filename="../../CommandCreateGeo.cpp" line="3418"/>
      <location filename="../../CommandCreateGeo.cpp" line="3448"/>
      <location filename="../../CommandCreateGeo.cpp" line="3775"/>
      <location filename="../../CommandCreateGeo.cpp" line="4118"/>
      <location filename="../../CommandCreateGeo.cpp" line="4416"/>
      <location filename="../../CommandCreateGeo.cpp" line="4448"/>
      <location filename="../../CommandCreateGeo.cpp" line="4950"/>
      <location filename="../../CommandCreateGeo.cpp" line="4994"/>
      <location filename="../../CommandCreateGeo.cpp" line="5025"/>
      <location filename="../../CommandCreateGeo.cpp" line="5308"/>
      <location filename="../../CommandCreateGeo.cpp" line="5335"/>
      <location filename="../../CommandCreateGeo.cpp" line="5515"/>
      <location filename="../../CommandCreateGeo.cpp" line="5544"/>
      <location filename="../../CommandCreateGeo.cpp" line="5572"/>
      <location filename="../../CommandCreateGeo.cpp" line="5852"/>
      <location filename="../../CommandCreateGeo.cpp" line="5881"/>
      <location filename="../../CommandCreateGeo.cpp" line="5912"/>
      <location filename="../../CommandCreateGeo.cpp" line="6142"/>
      <location filename="../../CommandCreateGeo.cpp" line="6456"/>
      <location filename="../../CommandCreateGeo.cpp" line="6575"/>
      <location filename="../../CommandCreateGeo.cpp" line="6759"/>
      <location filename="../../CommandCreateGeo.cpp" line="6935"/>
      <location filename="../../CommandCreateGeo.cpp" line="7191"/>
      <location filename="../../CommandCreateGeo.cpp" line="7384"/>
      <location filename="../../CommandCreateGeo.cpp" line="7411"/>
      <location filename="../../CommandCreateGeo.cpp" line="7438"/>
      <location filename="../../CommandCreateGeo.cpp" line="7466"/>
      <location filename="../../CommandCreateGeo.cpp" line="7493"/>
      <location filename="../../CommandCreateGeo.cpp" line="7520"/>
      <location filename="../../CommandCreateGeo.cpp" line="7547"/>
      <location filename="../../CommandCreateGeo.cpp" line="7578"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="100"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="131"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="162"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="193"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="224"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="255"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="384"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="452"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="525"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="602"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="756"/>
      <location filename="../../CommandSketcherBSpline.cpp" line="898"/>
      <location filename="../../CommandSketcherTools.cpp" line="102"/>
      <location filename="../../CommandSketcherTools.cpp" line="214"/>
      <location filename="../../CommandSketcherTools.cpp" line="301"/>
      <location filename="../../CommandSketcherTools.cpp" line="375"/>
      <location filename="../../CommandSketcherTools.cpp" line="421"/>
      <location filename="../../CommandSketcherTools.cpp" line="465"/>
      <location filename="../../CommandSketcherTools.cpp" line="508"/>
      <location filename="../../CommandSketcherTools.cpp" line="562"/>
      <location filename="../../CommandSketcherTools.cpp" line="616"/>
      <location filename="../../CommandSketcherTools.cpp" line="670"/>
      <location filename="../../CommandSketcherTools.cpp" line="722"/>
      <location filename="../../CommandSketcherTools.cpp" line="844"/>
      <location filename="../../CommandSketcherTools.cpp" line="929"/>
      <location filename="../../CommandSketcherTools.cpp" line="1024"/>
      <location filename="../../CommandSketcherTools.cpp" line="1539"/>
      <location filename="../../CommandSketcherTools.cpp" line="1585"/>
      <location filename="../../CommandSketcherTools.cpp" line="1628"/>
      <location filename="../../CommandSketcherTools.cpp" line="1662"/>
      <location filename="../../CommandSketcherTools.cpp" line="1944"/>
      <location filename="../../CommandSketcherTools.cpp" line="2084"/>
      <location filename="../../CommandSketcherTools.cpp" line="2147"/>
      <location filename="../../CommandSketcherTools.cpp" line="2211"/>
      <location filename="../../CommandSketcherVirtualSpace.cpp" line="92"/>
      <location filename="../../Workbench.cpp" line="37"/>
      <source>Sketcher</source>
      <translation>Эскизирование</translation>
    </message>
if we will be use:
#endif
location block compressed to one string:
  <context>
    <message>
      <location filename="../../Command.cpp" line="xxx"/>
    </message>
Founder
Post by wmayer »
Evgeniy wrote: Wed Sep 29, 2021 7:26 pm Why is this crutch often used in the code:
#endif
The advantage is that it's dead code and the compiler will ignore it while lupdate finds the strings and add them to the .ts files.
... begining
... command classes
It's theoretical possible but it has two disadvantages. You need to declare Sketch_workbench as global variable which is in general considered bad programming practice. And since in the Sketcher module the command classes are split into several source files you either must choose different identifiers or declare them with "extern". This complicates things quite a bit.
Evgeniy
Post by Evgeniy »
wmayer wrote: Wed Sep 29, 2021 8:50 pm
#endif
I understand this. And I noticed, these blocks:
    qApp->translate("Workbench", "Value");
#endif
are widely used in FreeCAD sources.
If we use it, we can change context, but we not change value.
And sGroup = "sketcher" won't tell the programmer anything. it is impossible to find out whether a string has a translation or not.
If we want to correct the name of the workbench, then we will have to search (it is unclear how) and rename all the lines.
For example if we use varibles we can change context and value by one string.
varible = QT_TRANSLATE_NOOP("WorkbenchNewContext","SketcherNewName");
sGroup = varible
sGroup = varible
sGroup = varible
For example what if we place this varible in "PreCompiled.cpp" or "PreCompiled.h"?
That file used in all command files:
Command.cpp , CommandAlterGeometry.cpp , CommandConstraints.cpp , CommandCreateGeo.cpp etc...
Maybe is possible to place this variable in it, for not create varible globally?
By the way. Im not find block
    qApp->translate("Workbench", "Sketcher");
#endif
in commit https://github.com/FreeCAD/FreeCAD/comm ... ce7b96560e
Do you add that block to commit?
Evgeniy
Post by Evgeniy »
cut
Founder
Post by wmayer »
Why not?
In the end for a programmer this is irrelevant.
If a global variable should be avoided and the group name Sketcher only in a single place then the easiest solution is to change the functions CreateSketcherCommands, CreateSketcherCommandsCreateGeo, ... that you find in Command*.cpp files. As argument they could use a std::list where all commands are added to (instead of using rcCmdMgr.addCommand).
Then in AppSketcherGui.cpp the commands of the list can be added to the CommandManager and there setGroupName("Sketcher") can be called.
Evgeniy
Post by Evgeniy »
I still came to the conclusion that my first solution with QT_TRANSLATE_NOOP ("Workbench", "sKetch") looks more correct than using variables or string.
Yes, it does not allow to rename all variables by one line. But it clearly shows all locations where the translation was applied and how many times it was applied. And show translation context. And with this commit https://github.com/FreeCAD/FreeCAD/commit/bc57ba6027 it should be work well.
Yes, in the end, this term will have a long context in Crowdin, but still for some reason it seems to me that this is the right solution.
