[Solved] Bug in ShapeString font preference ?
vk3ohm
Post by vk3ohm »
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
I am creating ShapeStrings, but every time I do I have to specify the font file. This operation works fine.
It occurred to me I should be able to set a default font folder/file, and you can - Preferences | Draft | Texts and dimensions | Default Shapefile font file, but every time I specify the font folder/file I get "Fonts You don't have permission to open this file". It's OK when I'm creating a ShapeString, so why not when I'm setting the preference?
Roy_043
Re: Bug in ShapeString font preference ?
Post by Roy_043 »
I have added a paragraph to the Wiki that describes the current situation and workarounds: Draft_ShapeString#Font_file_selection_on_Windows
GeneFC
Post by GeneFC »
Another workaround is to create a separate folder to contain copies of fonts that are used frequently. I don't use shapestrings, but I need font access in some other programs.
The new folder does not have the special permission magic that restricts use.
Gene
Roy_043
Re: [Solved] Bug in ShapeString font preference ?
Post by Roy_043 »
GeneFC wrote: Wed Sep 29, 2021 2:07 pm Another workaround is to create a separate folder
I remembered you suggesting that in a previous discussion. So that workaround was also added. :mrgreen:
