This does not help me since I have to create cut paths for a laser cutter. At the moment I take a sketch and export its elements as a single DXF and the laser cutter can directly use them.
Maybe using the Draft WB is an alternative?
Thanks.
OK. I understand.abdullah wrote: ↑Wed Sep 29, 2021 3:28 pm In such straightforward case, while for you it is evident the result (substract 4 DoF from the previous rank), it is not obvious for the software and it needs to calculate it. When it comes to a more serious delete, it is generally the case that you will have a very hard time to calculate the actual DoF, redundant constraints and so on. The software still does it (provided enough time is provided)...
So for Sketcher there is not much room for improvement, but for FC. I unfortunately don't have any knowledge regarding the calculation distribution over different CPU kernels. But I have e.g. 8 CPU kernels and it is sad to see that FC only uses one of it.
Then I often read that some calculations are fast on the GPU, so maybe this could be an option. Does anybody knows more about calculating on the GPU?
