No more linebreaks in tooltips ?
Chris_G
Post by Chris_G »
I was successfully using line breaks in tooltips before :
https://github.com/tomate44/CurvesWB/bl ... es.py#L238
They are now ignored :
Is there a way to get them back ?
carlopav
Re: No more linebreaks in tooltips ?
Post by carlopav »
Hi chris, probably my fault. New tooltips are created here: https://github.com/FreeCAD/FreeCAD/blob ... d.cpp#L855.
Current tooltip text ('ToolTip':) should not contain the command title, that is obtained through 'MenuText'.
Anyway the new function is not supposed to remove the line breaks... :cry: :roll:
carlopav
Post by carlopav »
Oh, could you try to use <br> instead of \n ?
Chris_G
Post by Chris_G »
<br> is working, thanks.
carlopav
Post by carlopav »
Great! I was lucky :)
sorry for the annoyance of having to rework your tooltips :(
Chris_G
Post by Chris_G »
No problem, they will be nicer like that ;)
Post by Kunda1 »
How did i miss this thread?
Roy_043
Post by Roy_043 »
Changing linebreaks to "<br>" does come with some issues:
Some workbenches (TechDraw) use the tooltip texts for the statusbar texts as well. Having "<br>" instead of "\n" in the text is then a problem. In the statusbar "\n" becomes a space, but "<br>" appears as is.
If the tooltip text contains multiple spaces (for indentation) those spaces are lost when "<br>" occurs in the text. You would have to replace them with "&nbsp;".
Tooltip texts converted to "<br>" have to be re-translated.
Related:
https://forum.freecadweb.org/viewtopic.php?f=10&t=65612
TheMarkster
Post by TheMarkster »
Python workbenches still need to support users with the latest stable 0.19, which means this string replacement "\n" to "<br/>" has to be done, but only if the version is >= 0.20. Could be better if FreeCAD did this replacement automatically?
carlopav
Post by carlopav »
TheMarkster wrote: Wed Feb 02, 2022 3:07 am Python workbenches still need to support users with the latest stable 0.19, which means this string replacement "\n" to "<br/>" has to be done, but only if the version is >= 0.20. Could be better if FreeCAD did this replacement automatically?
I think this could be good, but i think chris_g for example already replaced his tooltips in Curves...
Roy_043 wrote: Tue Feb 01, 2022 9:26 am Changing linebreaks to "<br>" does come with some issues:
If the tooltip text contains multiple spaces (for indentation) those spaces are lost when "<br>" occurs in the text. You would have to replace them with " ".
Related:
I Guess this is all mainly caused because i used the <h3> formatting of the header of the tooltips. It looks good, but perhaps this Is a change that can be reverted without a big loss
