AddonManager does not show up in Tools menu (FC 0.20.25843)
Smiling_user
Post by Smiling_user »
OS: Windows 7 SP 1 (6.1)
Version: 0.20.25943 (Git)
Hash: a65464b722a846bd2999aa2fecdff1132b15b297
Python version: 3.8.12
Qt version: 5.12.9
OCC version: 7.5.2
FreeCAD_weekly-builds-25645-Win-Conda_vc14.x-x86_64.7z
FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64.7z
- both same issue: AddonManager does not show up in Tools menu.
Running as portable, out of the box, or with a FC.bat file (which works nicely with 0.19.2):
set CURRENTDIR=%cd%
set FREECAD_USER_HOME=%CURRENTDIR%
start bin\FreeCAD.exe -u FreeCAD/user1.cfg -s FreeCAD/system1.cfg --write-log
What can be the issue, and how to repair it?
GeneFC
Re: AddonManager does not show up in Tools menu (FC 0.20.25843)
Post by GeneFC »
Works here.
Most likely is that your config file does not have the entries for the Addons. Portable or not, it is still necessary to have a set of configuration files.
Version: 0.20.25844 (Git)
Hash: 1b20118dfa3fb9f127f0e4fb122701f7fcdaa9fc
Qt version: 5.12.9
OCC version: 7.5.2
Gene
chennes
Post by chennes »
If you open up the Macros dialog and hit the "Addons" button, does the Addon Manager launch? Or do you get any error message? I thought that menu item was configured to always show when the Addon Manager was built regardless of whether it can run or not.
Chris Hennes
Pioneer Library System
Smiling_user
1.
chennes wrote: Mon Oct 04, 2021 12:26 am I thought that menu item was configured to always show when the Addon Manager was built regardless of whether it can run or not.
I thought the same. But it does not show up. And Macro> Addons... does not work: no error message, nothing.
User Macros Location: Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\FreeCAD\Macro/
2.
Is there any testing sequence for python console to see what is the issue?
3.
GeneFC wrote: Sun Oct 03, 2021 11:31 pm Most likely is that your config file does not have the entries for the Addons. Portable or not, it is still necessary to have a set of configuration files.
Gene, what should be inside the config Files in regards to AddonManager?
And did I understand correct, that you compiled your version from GIT?
4.
Removed all files from \Roaming\FreeCAD
made a new-clean unpacking from the downloaded archives:
All the same: Standard workbenches are available.
Tools>AddonManager - not shown
Macro >Macros...>Addons - does not launch the AddonManager
Workbenches Manually-copied to Mod folder - are not available.
5.
Could anyone tell me the "bootstrap" sequence of AddonManager? So I could go through the code, and try to find the issue?
For example:
1. on start freecad.exe looks in the ...*.cfg, reads the location of ...
2. goes to location ... looks in each directory for a file ___.....*.py
3. If the file contains the line like "......." then this file is added to a list of loaded workbenches....
//Long ago, when was trying to solve the portability issue - to make AddonManager to save all downloaded workbenches locally - I faced this issue of A-M. disappearing from Tools. But don't remember now what these changes were.
Last edited by Smiling_user on Tue Oct 05, 2021 12:28 pm, edited 4 times in total.
GeneFC
Post by GeneFC »
Smiling_user wrote: Tue Oct 05, 2021 6:30 am Gene, what should be inside the config Files in regards to AddonManager?
I downloaded that version directly from the download page. I compile sometimes, but not that particular version.
I do not know what should be inside the user.cfg. The addon manager entries in my user.cfg include only things like window positions and plugin references. However, I believe the Addon Manager is similar to a workbench. There is an Addon Manager folder in the Mod folder under the FreeCAD top level. If you are playing around with making things portable it is possible that something was moved improperly.
Gene
Smiling_user
I've launched the FC in both approaches: unpack downloaded and run or unpack downloaded and run it with my FC.bat.
in both cases - the same with version
"FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64.7z"
But the version
"FreeCAD_0.20.25645_Win-LPv12.5.4_vc17.x-x86-64.7z"
even does not allow to run main workbenches.
Possibly, something is wrong with access policies on my PC. But it is standard Thinkpad installation of Win7x64.
At current moment, the Report view gave me the following:
19:30:14  During initialization the error "[WinError 87] The parameter is incorrect" occurred in Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\Mod\AddonManager___\InitGui.py
19:30:14  Please look into the log file for further information
19:30:18  During initialization the error "[WinError 87] The parameter is incorrect" occurred in freecad.asm3
19:30:18  --------------------------------------------------------------------------------
19:30:18  Traceback (most recent call last):
  File "<string>", line 156, in InitApplications
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\importlib\__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 843, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\freecad\asm3\init_gui.py", line 3, in <module>
    from .utils import mainlogger as logger
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\freecad\asm3\utils.py", line 11, in <module>
    import numpy as np
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\numpy\__init__.py", line 150, in <module>
    from . import core
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\numpy\core\__init__.py", line 102, in <module>
    from . import _internal
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\site-packages\numpy\core\_internal.py", line 15, in <module>
    import ctypes
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\ctypes\__init__.py", line 468, in <module>
    GetLastError = windll.kernel32.GetLastError
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\ctypes\__init__.py", line 443, in __getattr__
    dll = self._dlltype(name)
  File "Z:\FreeCAD_weekly-builds-25943-Win-Conda_vc14.x-x86_64\bin\lib\ctypes\__init__.py", line 373, in __init__
    self._handle = _dlopen(self._name, mode)
OSError: [WinError 87] The parameter is incorrect
19:30:21  Unknown command 'Std_AddonMgr'
Smiling_user
Tryed this:
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
And got a report:
20:29:41  During initialization the error "[WinError 127] The specified procedure could not be found: 'Z:\\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\\bin\\lib\\site-packages\\shiboken2'" occurred in Z:\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\Mod\AddonManager\InitGui.py
20:29:41  Please look into the log file for further information
20:29:42  During initialization the error "[WinError 127] The specified procedure could not be found: 'Z:\\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\\bin\\lib\\site-packages\\shiboken2'" occurred in Z:\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\Mod\Arch\InitGui.py
20:29:42  Please look into the log file for further information
20:29:43  During initialization the error "[WinError 127] The specified procedure could not be found: 'Z:\\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\\bin\\lib\\site-packages\\shiboken2'" occurred in Z:\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\Mod\Draft\InitGui.py
20:29:43  Please look into the log file for further information
20:29:44  During initialization the error "[WinError 127] The specified procedure could not be found: 'Z:\\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\\bin\\lib\\site-packages\\shiboken2'" occurred in Z:\FreeCAD-0.19.2.7b5e18a-WIN-x64-portable1\Mod\Tux\InitGui.py
20:29:44  Please look into the log file for further information
20:29:46  DLL load failed while importing StartGui: The parameter is incorrect.
Smiling_user
Tryed also:
Python version: 3.8.8
Qt version: 5.12.9
OCC version: 7.4.0
And received in Report view:
20:36:17  During initialization the error "[WinError 87] The parameter is incorrect" occurred in Z:\FreeCAD_0.19.24291-Win-Conda_vc14.x-x86_64\Mod\AddonManager\InitGui.py
20:36:17  Please look into the log file for further information
20:36:22  Unknown command 'Std_AddonMgr'
## So for some reason even in the version 0.19. AddonManager stopped working for me...
What could cause this???
GeneFC
Post by GeneFC »
Smiling_user wrote: Tue Oct 05, 2021 8:37 pm What could cause this???
I have no real idea what is happening, but clearly something is not loaded in the correct location.
Just for fun I downloaded the portable version and opened it after hiding my usual user.cfg. The portable version worked fine and the Addon Manager menu item was visible and working.
The so-called portable version did create a new user.cfg and a Macro folder in the typical location. I think the portable version may not be really portable, but rather it is a version that does not "install".
If you somehow made the version really portable, such as on a USB stick, there may be some missing configuration files.
Gene
Smiling_user
Gene, well, to me it seems to be an issue with file-access-rights. Hear-ed, that the new python version is sensitive to this.
Now - after the newly unpacked version 0.19.2 does not load the same way as the 0.20 - it is definately something with my windows installation or unpacking program.
The "portability" file - just sets FC to run completely locally in a single folder. Only Macros and parts library folders are configured separately.
But who could point to the issue? How to solve the clue. And also this case probably is not a bug of FC...
After setting security settings to "Full control" to all groups of users, the report view still gives out:
22:32:19  During initialization the error "[WinError 87] The parameter is incorrect" occurred in Z:\FC20\Mod\AddonManager\InitGui.py
22:32:19  Please look into the log file for further information
22:32:23  During initialization the error "[WinError 87] The parameter is incorrect" occurred in freecad.asm3
22:32:23  --------------------------------------------------------------------------------
22:32:23  Traceback (most recent call last):
  File "Z:\FC20\bin\lib\importlib\__init__.py", line 127, in import_module    return _bootstrap._gcd_import(name[level:], package, level)
  File "Z:\FC20\bin\lib\site-packages\freecad\asm3\init_gui.py", line 3, in <module>     from .utils import mainlogger as logger
  File "Z:\FC20\bin\lib\site-packages\freecad\asm3\utils.py", line 11, in <module>     import numpy as np
  File "Z:\FC20\bin\lib\site-packages\numpy\__init__.py", line 150, in <module>     from . import core
  File "Z:\FC20\bin\lib\site-packages\numpy\core\__init__.py", line 102, in <module>     from . import _internal
  File "Z:\FC20\bin\lib\site-packages\numpy\core\_internal.py", line 15, in <module>     import ctypes
  File "Z:\FC20\bin\lib\ctypes\__init__.py", line 468, in <module>     GetLastError = windll.kernel32.GetLastError
  File "Z:\FC20\bin\lib\ctypes\__init__.py", line 443, in __getattr__     dll = self._dlltype(name)
  File "Z:\FC20\bin\lib\ctypes\__init__.py", line 373, in __init__     self._handle = _dlopen(self._name, mode)
22:32:26  Unknown command 'Std_AddonMgr'
