Linux compliation Git question
Evgeniy
Post by Evgeniy »
Read at first:
https://stackoverflow.com/questions/626 ... -clean-fdx
May this recommendation is danger?
> .gitignore
git clean -df
git reset --hard HEAD
getted from:
https://wiki.freecadweb.org/Compile_on_Linux
chennes
Re: Linux compliation Git question
Post by chennes »
Well, that operation is designed to be destructive... so I guess you could argue it's dangerous, in much the same way that saying to delete the contents of your build directory with rm -rf * is destructive. Definitely make sure you do it in the directory you mean to! It's a set of steps designed to clean up a mistake, basically.
Chris Hennes
Pioneer Library System
Evgeniy
Post by Evgeniy »
May be worth adding a comment that this operation should be performed in the source directory. And that improper use can lead to data loss.
chennes
Post by chennes »
Wouldn't hurt --- do you have wiki edit access?
Chris Hennes
Evgeniy
Post by Evgeniy »
chennes wrote: Tue Oct 05, 2021 2:10 pm Wouldn't hurt --- do you have wiki edit access?
Yes. But how can I describe it better?
