Sketcher grid disapperans when document is saved
anthonyg
Post by anthonyg »
OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.19.
Python version: 3.9.7
Qt version: 5.15.2
OCC version: 7.5.1
When in sketcher workbench, when the document is saved the grid disappears, it reappears sometime later while editing the sketch or when clicking Edit -> Refresh (CRTL + R).
openBrain
Re: Sketcher grid disapperans when document is saved
Post by openBrain »
Confirmed. Looks like a bug.
Indeed, grid comes back if changing its dimension, or leaving/re-entering sketch (certainly because it forces a redraw).
Will have a look if some time for it. If nothing is done within a week or two, we may open a ticket in the tracker.
OS: Ubuntu 21.04 (KDE/plasma)
Version: 0.20.26271
Hash: d8f38a886ae66f4f3e61df3031c855eb09490489
Python version: 3.9.5
Qt version: 5.15.2
OCC version: 7.5.2
Locale: French/France (fr_FR)
openBrain
Post by openBrain »
anthonyg wrote: Mon Oct 25, 2021 10:37 pm When in sketcher workbench, when the document is saved the grid disappears, it reappears sometime later while editing the sketch or when clicking Edit -> Refresh (CRTL + R).
That was a very beneficial issue report as it finally pointed me to an incorrect equation in the grid visibility management.
Once fixed, even allows to remove some lines that has been added to workaround the root issue. ;)
Pull request is here : https://github.com/FreeCAD/FreeCAD/pull/5138
Syres
Post by Syres »
openBrain wrote: Tue Nov 02, 2021 6:49 pm Pull request is here : https://github.com/FreeCAD/FreeCAD/pull/5138
So looks like it can be backported to 0.19 branch at the same time as merging into master?
openBrain
Post by openBrain »
Syres wrote: Wed Nov 03, 2021 8:35 am So looks like it can be backported to 0.19 branch at the same time as merging into master?
Not sure it is of higher importance as this isn't a very inconvenient bug with high occurrence, but it should backport without any issue though.
uwestoehr
Post by uwestoehr »
openBrain wrote: Wed Nov 03, 2021 11:48 am Not sure it is of higher importance as this isn't a very inconvenient bug with high occurrence, but it should backport without any issue though.
But it was an annoying one. Many thanks for the fix.
I merged the PR and also backported since FC 0.19.3 should be released soon.
openBrain
Post by openBrain »
uwestoehr wrote: Fri Nov 05, 2021 2:42 am But it was an annoying one. Many thanks for the fix.
Maybe I'm not fair as I don't use grid. :) Anyway trust you to know what should be backported. ;)
