[fixed] SSL certificate for freecadweb.org expired
uwestoehr
Re: SSL certificate for freecadweb.org expired
Post by uwestoehr »
Notifying Yorik
yorik wrote: .
user1234
Post by user1234 »
It seems that Yorik fixed that, thanks!
Greetings
user1234
uwestoehr
Post by uwestoehr »
user1234 wrote: Tue Oct 26, 2021 6:19 pm It seems that Yorik fixed that, thanks!
Yes, many thanks!
(I will open a new thread for the remaining forum issues.)
yorik
Founder
Re: [fixed] SSL certificate for freecadweb.org expired
Post by yorik »
Kurt is who fixed it ;)
splainer
Post by splainer »
Seems this is not fully fixed?
I have debugged my issue from this post Cannot run BIM Tutorial. The attempt to load the URL https://www.freecadweb.org/wiki/BIM_ingame_tutorial in BimTutorial.py throws exception:
URLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1125)'))
Syres
Post by Syres »
splainer wrote: Wed Dec 22, 2021 10:09 pm Seems this is not fully fixed?
I'm going to assume you're on Windows, I believe the issue is the OpenSSL version that's shipped with the Windows builds that's the root cause but I'm happy to be corrected.
yorik
Founder
Post by yorik »
@splainer everything normal here... does opening https://wiki.freecadweb.org/BIM_ingame_tutorial in a browser work for you? If yes, I suppose @Syres's explanation is correct.. Strange that nobody else reported this, though...
splainer
Post by splainer »
Yes, I can open that page in every browser (Brave, Edge, IE, Chrome) I have with no issue.
