OS: Debian GNU/Linux 11 (bullseye) (XFCE/lightdm-xsession)
Version: 0.19.
Python version: 3.9.7
Qt version: 5.15.2
OCC version: 7.5.1
On Sketcher, when I enter a division, it can display a wrong value, see image bellow where it displays 4.83 instead of 4.825:
Also, after entering a value and editing the formula it can display a wrong value:
The value I entered was 8.79mm / 2, and now it's showing 8.789999999999999mm / 2.
Sketcher formula displays incorrect values
- Shalmeneser
Re: Sketcher formula displays incorrect values
Please follow the banner in Help forum : version, ...
How many decimals did you set in the preferences?
OK, I though there would be something wrong because on the drawing itself you can see it displays 4.825.So how surprising it is that is displays 4.83 instead of 4.825 ???
Yep. There are some inconsistencies/weirdness in FreeCAD where user setting is sparsely applied.
Especially for Sketcher, it has a hardcoded precision that value is "6 significant digits". We discussed that already but no decision was made about a change : https://forum.freecadweb.org/viewtopic.php?f=3&t=61740
Regarding your other issue, it is due to some classical floating-point number representation. It's a bit weird but not so easy to tackle.
Python has some nice and detailed explanation: https://docs.python.org/3/tutorial/floa ... tion-errorRegarding your other issue, it is due to some classical floating-point number representation. It's a bit weird but not so easy to tackle.
