I wanted to begin using the Spreadsheet Module, but I get the following error when I open your file:eivindkvedalen wrote:Attached is an example where some properties of the part are calculated.sgrogan wrote:Ca someone give me examples with this simple file.
Eivind
cd Programs/Original/build/bin && ./FreeCAD
FreeCAD 0.16, Libs: 0.16R4783 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015
*** Abort *** an exception was raised, but no catch was found.
... The exception is:SIGSEGV 'segmentation violation' detected. Address 0
OS: Linux
Version: 0.16.4783 (Git)
Hash: 6a6a3d3bd05144e910741c88491f86bf0142acea
Python version: 2.7.9
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.8.0.oce-0.17
Steps to reproduce:
- Open FreeCAD from terminal or menu
- Open your file
Isaac
EDIT
Running gdb, I get:
#0 0x00007ffff639f47a in xercesc_3_1::ReaderMgr::peekNextChar() ()
from /usr/lib/libxerces-c-3.1.so
Backtrace stopped: Cannot access memory at address 0x7fffffffb9e8
issue#2048
