Mirroring previous pad operation affects holes on mirrored part?
MikeLemon
Post by MikeLemon »
I'm trying to create a real simple part to experinment with an optical encoder and after I extrude a face make a pocket in it and then mirror just the pad op the hole on the original extruded face gets blocked like that:
after mirroring pad001 across XZ plane
Running yesterdays version of debug build FC 0.20 26413 GIT
Anyidea why this happens?
Also in the second screenshot where the red line mark and the arrow is, why isn't this whole face becomes one istead of 3 separate rect faces?
Is there a way to tell FC to simplify the faces in the model?
The same goes for hole faces, why does it look like a rolled paper instead of a seamless cylinder?
openBrain
Re: Mirroring previous pad operation affects holes on mirrored part?
Post by openBrain »
Please attach file.
On your screenshots, model isn't recomputed.
Shalmeneser
Post by Shalmeneser »
Waiting for your file...
Mirror.FCStd
(28.16 KiB) Downloaded 14 times
Capture du 2021-11-18 20-49-39.png (26.27 KiB) Viewed 1601 times
UR21
Post by UR21 »
In my FC 0.19 the File "Haarschleife .." doesn't look like the screenshots. It seems to be another part.
Shalmeneser
:oops: redownloaded above
