[Temporarly Solved] Design456 will die if I don't get some help
I am quite sure that there is a serious problem with the engine and the core of FreeCAD which make my Workbench development impossible.
"Recreating objects" is the base of the project. Not been able to do that in a responsive way, specially for so small amount of faces (which were 6 only), means that there is no solution for my WB with OCCT.
Now, Coin3D is not the answer. I don't think Coin provide better/easy way of drawing objects. I tried too hard to use it and I don't like it at all.
Now, I am not aware of any other CAD engine that is available ( I am not so deep in the question), but you might know and you (might) tried different things.
Please let me know if there are any other possibilities out there. Don't know which library would make sense to use.
I am really wishing to get a way to continue. I love so much the project that I cannot imagine it is the end..
the end is painful.
Hope for some help.
Best Regards,
Mariwan
the end is painful.
Hope for some help.
Best Regards,
Mariwan
Design456 Direct Modeling. Coin3D GUI Toolkit. Objects get simplified.
https://github.com/MariwanJ/Design456 - https://wiki.freecadweb.org/Design456_Workbench
https://www.youtube.com/watch?v=6agcHPd ... utbTDH93m_
- adrianinsaval
Re: Design456 will die if I don't get some help
I noticed the other you set a tolerance value in your code, does increasing the tolerance help? You could try doing something with openscad, not sure if that would be faster.
The approach you are using is not sustainable with FreeCAD. You cannot recompute the document every time the mouse moves, that's just crazy!
I suggest you to try to recompute just the shape, do not add it to the object but only display it in coin. If it's not fast enough, just recompute the edges and display them in coin. Apply the shape to the object and recompute only at the end of the action.
Eventually you could have a look at how PartDesign preview works in master branch or in RT fork.
The tolerance is for the end. It is not used yet. The only thing I do is to recreate the faces with new vertexes I get from moving the edge.adrianinsaval wrote: ↑Fri Nov 26, 2021 12:13 pm I noticed the other you set a tolerance value in your code, does increasing the tolerance help? You could try doing something with openscad, not sure if that would be faster.
That part is to fix problem with the solid version of the faces.
thanks anyway
Carlopav,carlopav wrote: ↑Fri Nov 26, 2021 1:11 pm The approach you are using is not sustainable with FreeCAD. You cannot recompute the document every time the mouse moves, that's just crazy!
The problem with Coin: It is not so easy either. The code will be huge and terrible for nothing.
Recomputing only the edge, will not give the normal feeling of Direct Modeling.
If I cannot recompute the document, which I don't do - I removed them all, it is done automatically, then there is no direct modeling. You need to modify objects and get the feeling that you are modifying them on-fly .. not after you release the mouse.
Thanks anyway.
As other mentioned, Part.makeFilledFace is causing the issue .. Which is OCCT+FreeCAD code.
BR
did you try to stop before face reconstruction and get the visual through:
Shape.writeInventor()
Didn't helpcarlopav wrote: ↑Fri Nov 26, 2021 4:29 pm did you try to stop before face reconstruction and get the visual through:?Code: Select all
Maybe creating a hybrid CAD using two CAD kernels, one fast (Mesh - based) and second precise (B-Rep - based) could solve this?
How I see this:
1. Two CAD kernels work asynchronously, the fast one is used for interaction with user, previews etc.
2. The precise one is independent from user interactions, and can recompute at much lower rate. In the worst case, only for file save/export.
3. Both kernels use the same user input as data. If a shape is not available in the fast one API, then precise one creates it and converts to mesh as fast one input data.
The precise kernel would be OpenCASCADE.
The fast one, maybe ImplicitCAD? I'm not sure how flexible it is, but it seems to be fast at least.
From FAQ:
ImplicitCAD has a perfect internal model of your object. It is of near-infinite resolution. In order to access it, it is rendered into an approximating triangle mesh, a raytraced image or GCode. These approximations can be of varying quality, depending on what you request.
Is ImplicitCAD Faster than OpenSCAD?
It depends. In most cases, probably.
The speed of ImplicitCAD depends on quality of the rendering you are trying to make. To make models of comparable quality to their OpenSCAD counter parts, ImplicitCAD is generally much faster.
OpenSCAD's performance drastically slows down as objects get more complex. ImplicitCAD's performance is much less affected by the complexity of the objects it is rendering (more affected by the quality of object you ask it to render). ImplicitCAD also often has simpler ways of representing objects than OpenSCAD.
ImplicitCAD is capable of parallel rendering. Unlike OpenSCAD, it is happy to use more threads and be faster!
Thank you very much for your suggestion.kwahoo wrote: ↑Fri Nov 26, 2021 7:35 pm Maybe creating a hybrid CAD using two CAD kernels, one fast (Mesh - based) and second precise (B-Rep - based) could solve this?
How I see this:
From FAQ:...
This might be a solution.
I must:
-Know how to install it - User install it
-Use it in the current problematic tool.
-If I success in that, Any tool needs more speed should use this library. Or I make it more general and use it everywhere? don't know now.
I work on that directly. Thanks again.
Oh!!
Windows / Mac Packages
Sadly, ImplicitCAD packages have not been made for these operating systems yet.
