Line clipping algorithms
MRx
Post by MRx »
does anyone know are there any line clipping algorithms implemented in FreeCAD or in the connected libraries?
There are a few options, I need one for the outline path generation.
https://forum.freecadweb.org/viewtopic. ... 69#p549935
I want to clip every single path as soon as it leaves a defined area / stock (maybe plus/minus some offset)
https://en.wikipedia.org/wiki/Line_clipping
Problem solved, Zheng Lei directed me to Path.Area which already has an implementation for this.
just something like that:
Part.show(Path.Area().add([FreeCAD.ActiveDocument.Sketch002.Shape, FreeCAD.ActiveDocument.Sketch.Shape], op=2).getShape())
onekk
Re: Line clipping algorithms
Post by onekk »
line clipping is somewhat different, from Path.Area.
You could find the intersection of the lines and rearrange start and ending points (I intend it using scripting).
same for extend, there are also some OOCT methods that do such things.
from draftgeoutils.intersections import findIntersection
np_a = line1
np_a = line2
cc = findIntersection(np_a, np_b, True, True)
# this is a list of intersection points
Hope it helps
Carlo D.
- Various other stuffs.
