[fixed] need help to understand why import ImportGui fails
uwestoehr
Post by uwestoehr »
I am in the making of a Windows build for FC 0.19.3 and I am stuck.
Upon my request to test my builds I realized that it cannot handle STEP files. I could track it down to ImportGui but don't know how to fix it.
In the Python console of my build I enter:
>>>  import ImportGui
  File "D:\FreeCAD-build\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import
ImportError: DLL load failed while importing ImportGui: Das angegebene Modul wurde nicht gefunden.
>>> import PartGui
>>> import PartDesignGui
So importing ImportGui fails while e.g. importing PartGui works without problems.
The problem only exists with the latest LibPack 12.5.3. With LibPack 12.5.2 it works fine but this LibPack contains an older OCC 7.5 version and the users want to benefit from fixes in the handling of STEP by OCC.
I guess the problem is somewhere in a CMake file but I have almost no knowledge about CMake. Does anybody has an idea or could point me to files I should look at?
OS: Windows 10 Version 2009
Version: 0.19.24365 (Git)
Branch: releases/FreeCAD-0-19
Hash: c5eca93a2070fe67957350ef8371e53027364c69
Python version: 3.8.6+
Qt version: 5.15.1
Coin version: 4.0.1
OCC version: 7.5.2
wmayer wrote: .
uwestoehr
Re: need help to understand why import ImportGui fails
Post by uwestoehr »
chennes wrote: .
sgrogan wrote: Sat Jul 22, 2017 2:24 pm .
uwestoehr
Post by uwestoehr »
I tested now all Workbenches and I get the same error when I load
- Gui.activateWorkbench("FemWorkbench")
- Gui.activateWorkbench("TechDrawWorkbench")
Also the Start WB shows broken HTML code is if a CSS file is broken.
I have no explanation why other WBs like PartDesign or Sketcher work well. I thought that when I made a mistake in my compilation setup it will affect all WBs.
uwestoehr
Post by uwestoehr »
I could boil down all issues down to one single DLL: TKService.dll
So when I take the LibPack but only replace this single DLL:
TKService-OOC752-buggy.zip
(343.39 KiB) Downloaded 41 times
and use instead the one from the prior LibPack that uses OCC 7.5.0:
TKService-OCC-750.zip
(623.32 KiB) Downloaded 47 times
everything works fine for me so far.
Here is a new Windows installer I built with the result: https://github.com/donovaly/FreeCADInst ... ller-3.exe
It uses the latest LibPack, meaning OCC 7.5.2. Additionally
- I upgraded Qt to 5.15.2
- I fixed two CMake errors: https://github.com/apeltauer/FreeCAD/issues/13
- use the TKService.dll from OCC 7.5.0 (taken from the prior LibPack)
Here is the resulting LibPack I got and used to build (the changed TKService.dll is not included): https://github.com/donovaly/FreeCADInst ... ixes_US.7z
I don't know now how to proceed. Is it OK to keep the single DLL from OCC 7.5.0 and use all other from OCC 7.5.2? If so, I would release the Win installer in that state - if I get no error reports from it in the announcement thread: https://forum.freecadweb.org/viewtopic.php?f=9&t=64025
Founder
Post by wmayer »
Use the tool dependency walker to see all dependencies to further dlls of a given dll. Since you already know that TKService.dll causes problems then load it with the tool and in case of missing dlls they should be listed.
uwestoehr
Post by uwestoehr »
wmayer wrote: Sun Nov 28, 2021 9:58 am Use the tool dependency walker to see all dependencies to further dlls of a given dll. Since you already know that TKService.dll causes problems then load it with the tool and in case of missing dlls they should be listed.
Many thanks! I did not know this tool before.
It shows that it depends on a missing LIBFREETYPE-6__.DLL:
This dependency is not necessary. It came it because of a wrong CMake include setting once OCC was compiled as I found out.
Since this dependency is not necessary, here the result of TKService.dll from the LibPack with which we released FC 0.19.2:
I think it is safe the to make the release as I did it in my test build: only the TKService.dll is the one from the prior LibPack. dependency walker shows me that in this case all DLL used by dependency walker are the ones from OCC 7.5.2. So users can benefit from the OCC 7.5.x fixes.
uwestoehr
Post by uwestoehr »
For the records, here is a fixed LibPack in which I fixed all issues I listed described here: https://github.com/apeltauer/FreeCAD/issues/19
uwestoehr
Re: [fixed] need help to understand why import ImportGui fails
Post by uwestoehr »
@apeltauer released today a new LibPack and in this the issue I reported here is fixed: https://github.com/apeltauer/FreeCAD/re ... ack_12.5.4
