Hiding the test runner window
chennes
Post by chennes »
While the tests are running using the Test WB, sometimes the runner window seems to be getting hidden/occluded/whatever -- how is that done? I'm still trying to get testing of copy and paste working, and I think the events are going to the test runner window instead of the main 3D view. I'm hoping if I actually hide the runner window that will stop.
Chris Hennes
Pioneer Library System
Re: Hiding the test runner window
Post by Kunda1 »
I've wondered about this too!
adrianinsaval
Post by adrianinsaval »
if it's a qtwidget shouldn't it have a show/hide function?
chennes
Post by chennes »
Yeah, but how does a running test get at the widget? Do I have to get the list of windows from the QCoreApplication and iterate over it, or something along those lines?
Chris Hennes
TheMarkster
Post by TheMarkster »
This might (or might not) work:
Gui.getMainWindow().setFocus()
chennes
Post by chennes »
TheMarkster wrote: Sun Dec 19, 2021 2:50 am This might (or might not) work:
No luck, I think because the test runner window is modal.
Chris Hennes
Founder
Post by wmayer »
No, it's non-modal.You can easily see this when opening the test dialog but not starting the tests. Then you can still interact with the main window by opening the menus, ....
Here I already explained why directly calling the Copy & Paste commands do not give the expected result.
Now when you create a spreadsheet and open the test dialog (or any non-modal dialog) you will see that the Copy & Paste commands are greyed out. In order to make them active again a way is to switch to another application and then back to FreeCAD.
This as a regression of RT's changes of the Link branch where a timer to regularly (200 ms) update all command actions has been replaced to update them on request. There are still a couple of use cases where the commands are not updated when needed.
Now the whole thing is very fragile in order to be tested with unit tests and I recommend to avoid to use the general Copy & Paste command and instead send the messages directly to the correct window.
chennes
Post by chennes »
wmayer wrote: Sun Dec 19, 2021 10:47 am Now the whole thing is very fragile in order to be tested with unit tests and I recommend to avoid to use the general Copy & Paste command and instead send the messages directly to the correct window.
Thanks, I will take that approach then.
Chris Hennes
