Supporting Qt 6 - What's needed?
berniev
Re: Supporting Qt 6 - What's needed?
Post by berniev »
For a bit of fun, and figuring that if I am going to learn stuff it might as well be good future stuff ...
I am attempting build with Qt6.31, Pyside6, Shiboken6, Python3.10, C++20.
Seems like a reasonable goal!!
Of course I'm hitting bumps all over the place. Anyone wanna talk about it? (very quiet here lately)
VTK is not python3.10, but close.
Bunch of deprecations in Qt6 which are used quite a bit in FC
chennes
Post by chennes »
Are you using the Clazy-Qt6 checks? That would be an easy place to start -- I mean, it's going to mean a lot of code, but conceptually anyway it's not difficult, we just have to make sure to continue to support Qt 5.9, so lots of preprocessor directives in C++, and probably hasattr in Python (at least, that's how I've handled the QRegExp/QRegularExpression stuff).
We can start committing this stuff anytime, since we aren't removing support for older Qt versions, just adding support for the new one, and it doesn't have to happen all at once. Once we have enough we'll turn on the Clazy-Qt6 stuff in our own CI.
Chris Hennes
Pioneer Library System
berniev
Post by berniev »
For how long?
Is this the accepted plan, or your thoughts?
That would be horrible!
Twice, and duplicated the code.
Have you looked at Qt6 Core5Compat?
chennes
Post by chennes »
berniev wrote: Tue Sep 27, 2022 1:31 pm
For how long?
Until Ubuntu 18.04 LTS end of life (so something like six months from now) as I recall. We discussed this when we were releasing 0.20, but maybe @wmayer would care to weigh in. It would make life a lot easier if we could advance that (since I think it's unlikely that 1.0 will be ready before 18.04 is EOL).
Yes, having to support two versions of Qt is ugly, but there isn't a way around it. Even if we were to advance all the way to 5.15 as the minimum (and I think 5.12 is more likely) I believe there are still some things that will have to be conditionally compiled in C++. As far as I'm concerned the situation in Python is even worse, because it's not as well documented, and PySide6 does things like drop support for the Qt resource system entirely.
Right -- if I have to do it a third time I guess I'll get around to refactoring :).
I knew it existed, but I haven't used it for anything.
Chris Hennes
adrianinsaval
Post by adrianinsaval »
I see no point in supporting 18.04 in git master, it's not going to be released before it reaches EOL and the daily ppa is broken anyways. Plus nowadays the rare users of it can resort to appimage/snap/flatpak/conda
berniev
Post by berniev »
Apparently that is no longer the problem it was:
adrianinsaval
I don't know if this was an issue for pyside too but note that the stackoverflow question and answer are about pyqt, FreeCAD uses pyside, not pyqt
berniev
Post by berniev »
adrianinsaval wrote: Tue Sep 27, 2022 3:58 pm I don't know if this was an issue for pyside too but note that the stackoverflow question and answer are about pyqt, FreeCAD uses pyside, not pyqt
Oops. Thanks for pointing that out! Back to Mr Google ..
berniev
Post by berniev »
In my searching I'm not seeing an issue. Could someone expand on this a bit?
Founder
Post by wmayer »
Sure, I can upgrade to Ubuntu 20.04 but this will take me some time to do that.
That is a fact we always have to deal with independent if the lowest Qt version is 5.9 or 5.12 because between two Qt versions there is always an API change. And if we support Qt5 and Qt6 then there will be even more #ifdef's. To reduce them in our code base we can implement some convenience functions. AFAIK in Qt 5.15 all classes or functions are marked deprecated that will be removed in Qt6 and therefore a couple of convenience functions have been implemented e.g. Base/Mutex.h, Base/QtTools, Gui/Tools.h, ...
Is there a reason for it? And what about Qt itself? Or is it rather that the Qt tools can be directly used for Python code?
The question is how useful it is. I remember that for the move from Qt3 to Qt4 there also was a support library but its main purpose was that you didn't get compile errors but functionality-wise pretty much everything was broken. So, there was no alternative than fully porting to Qt4 as soon as possible.
