Modify constrain value.
paddle
Post by paddle »
Say I want to modify a distance constrain value from my cpp function.
How should I do it?
I think it's probably something like
       Gui::cmdAppObjectArgs(Obj, "setDriving(%i,%s)", ConStr.size() - 1, "False");
       Gui::Command::commitCommand();
Which sets a constrain as driving.
Is there a setValue(%i) ? I'd rather not poke blindly for the correct function name. And I can't find the answer by browsing the source code because those functions are sent as string.
Thanks
Beside if there's a way without Gui::Command it would be better because I don't want to create an action in the history of the user for this modification.
Edit: Does that do the job?
                ConStr[ConStr.size() - 1]->setValue(sketchgui->toolSettings->widget->toolParameters[0]);
Edit2: It does work, the value of the constrain is changed, but it doesn't update the geometry. Not until you move something then the geometry jump to the correct length.
How to recompute ?
Edit3 :
                Obj->solve(true);
Does the job
TheMarkster
Re: Modify constrain value.
Post by TheMarkster »
paddle wrote: Tue Jan 18, 2022 5:55 pm
You could do something similar to doCommand() with, for example:
Base::Interpreter().runString("import FreeCAD")
and it won't appear in the python console.
I would prefer, I think, doing things in the Gui and watching the python console to get the python needed for doing this thing, such as changing a constraint value. Then do it using runString() or doCommand() rather than trying to do it all in c++ by accessing the sketch object directly. Keep in mind that when the user is recording a macro it needs to appear in the console for it to get into the macro.
openBrain
Post by openBrain »
I think you can just test by changing a constraint from the Property pane and see what happens in the Python console. ;)
