Delete a constrain from cpp?
paddle
Post by paddle »
I'm making a tool creating constrains. But if the user exit the tool without validating then I want to delete the constraint. How to do that?
I'm trying :
            Sketcher::SketchObject* Obj = sketchgui->getSketchObject();
            Obj->Constraints.setSize(Obj->Constraints.getSize() - numberOfConstraintsCreated);
            Obj->solve(true);
            sketchgui->draw(false, false); // Redraw
Which works but creates an illegal storage access (_onselectionchanged in selection.cpp).
I tried to
Gui::Selection().clearSelection();
first but doesn't seem effective.
Is it wrong to use the class destructor? Should my code be somewhere else? In deactivate function?
Edit : Using deactivated function of the DrawSketchHandler instead of the class destructor fixed the issue.
