Making constraint 'clear' when sketchHandler active
paddle
Re: Making constraint 'clear' when sketchHandler active
Post by paddle »
I think space key is good because it's easy to access. Specially if it's unused in this scope.
adrianinsaval
Post by adrianinsaval »
can you give me an example of what tool allows you to select a constraint? AFAIK none of them does anything with a preselected constraint so IMO adding a key to enable/disable this gives no benefit.
paddle
Post by paddle »
adrianinsaval wrote: Tue Jan 25, 2022 7:16 pm can you give me an example of what tool allows you to select a constraint? AFAIK none of them does anything with a preselected constraint so IMO adding a key to enable/disable this gives no benefit.
The idea is to add a key to enable it when not using a tool. On top of having it enabled all the time when a tool is active.
This is to help selecting geometries when sketch is complex and cluttered with constraints.
adrianinsaval
ah sorry for the noise, and why wouldn't it be possible to configure this key?
openBrain
Post by openBrain »
adrianinsaval wrote: Tue Jan 25, 2022 7:31 pm ah sorry for the noise, and why wouldn't it be possible to configure this key?
Roughly, this is handled in a very specific place in the code where key events are passed through view provider as pivy SoKeyboard values. Not as 'Qt shortcuts'.
An alternative to make this configurable would be to have a command that will toggle constraint selectability on and off. But as said, that would be toggle behavior : one key press turns off, next key press turns on, an so on.
Now, the behavior is "constraints aren't selectable while key is held pressed", which I find better for this usage.
openBrain
Post by openBrain »
OK, thought to this again and an alternative to 'Space' may be the 'Shift' key (which is roughly the lone modifier that isn't used to perform some actions already).
I tested on this morning. It works and doesn't prevent commands using 'Shift' in their shortcuts to work.
Would you prefer 'Shift' to 'Space' ?
paddle
Post by paddle »
Personally I prefer Space.
openBrain wrote: Wed Jan 26, 2022 8:28 am Would you prefer 'Shift' to 'Space' ?
Shift, Ctrl and friends are modifiers, which should be used to change the behaviour of an action in progress, such as the 45° angle restriction in Polyline. A key such as space can be used to change a certain state, such as the Polyline's continuation mode. The border between these two is not very sharp, but it exists. So you may decide how to handle it.
openBrain
Post by openBrain »
chrisb wrote: Wed Jan 26, 2022 6:05 pm Shift, Ctrl and friends are modifiers, which should be used to change the behaviour of an action in progress, such as the 45° angle restriction in Polyline. A key such as space can be used to change a certain state, such as the Polyline's continuation mode. The border between these two is not very sharp, but it exists. So you may decide how to handle it.
Based on this, your preferred choice is 'Shift'. :)
heron
Post by heron »
I often use the space bar while editing a sketch.
It is useful for documents with multiples parts such assemblyes when doing modifications or making sketechs to get references, for example.
Sorry for the late.
Regards.
