[Error] Sketcher - tangency constrain
paddle
Post by paddle »
CommandConstraints.cpp
Tangency constrain
void CmdSketcherConstrainTangent::applyConstraint(std::vector<SelIdPair> &selSeq, int seqIndex)
    int GeoId1 = GeoEnum::GeoUndef, GeoId2 = GeoEnum::GeoUndef, GeoId3 = GeoEnum::GeoUndef;
    Sketcher::PointPos PosId1 = Sketcher::PointPos::none, PosId2 = Sketcher::PointPos::none, PosId3 = Sketcher::PointPos::none;
    // check if the edge already has a Block constraint
    if ( areBothPointsOrSegmentsFixed(Obj,GeoId1,GeoId2) ) {
      showNoConstraintBetweenFixedGeometry();
      return;
    switch (seqIndex) {
    case 0: // {SelEdge, SelEdgeOrAxis}
    case 1: // {SelEdgeOrAxis, SelEdge}
    case 2: // {SelEdge, SelExternalEdge}
    case 3: // {SelExternalEdge, SelEdge}
        GeoId1 = selSeq.at(0).GeoId; GeoId2 = selSeq.at(1).GeoId;
areBothPointsOrSegmentsFixed(Obj,GeoId1,GeoId2) is called when GeoId1 and GeoId2 are GeoUndef. So this IF is useless.
I don't know if this IF has some use but the misplacement might cause some bad behaviour?
Re: [Error] Sketcher - tangency constrain
I don't know if Abdullah is scanning this forum, let's ping him:
Abdullah wrote:ping
openBrain
Post by openBrain »
Actually the check can just be removed because the selection mechanism already prevents selecting 2 external edges.
Do you want me to proceed and push a PR ?
paddle
Post by paddle »
openBrain wrote: Thu Jan 20, 2022 2:47 pm Actually the check can just be removed because the selection mechanism already prevents selecting 2 external edges.
Yes please go ahead !
adrianinsaval
Post by adrianinsaval »
I won't pretend to understand sketcher code but are you sure it's not needed? The comment mentions the block constraint, is this how external geometry are called in the code? or is this if relevant for the (GUI) block constraint?
Edit: checked the code https://github.com/FreeCAD/FreeCAD/blob ... 4108-L4116
getIdsFromName(SubNames[0], Obj, GeoId1, PosId1);
I have very little C++ knowledge but I thought you had to pass pointers as arguments if you wanted the called function to modify the values of the variables so this is confusing me, it seems here the values for GeoId are obtained with this function by passing them as arguments.
Anyways, so CmdSketcherConstrainTangent::activated already checks for "blocked" geometries (external, block constrained and bspline knots) it's then safe to assume this portion of code will always be executed before CmdSketcherConstrainTangent::applyConstraint so no check is needed inside that, is this correct?
Might be worth looking at how the rest of the constraints are doing this check to see if they have similar errors.
paddle
Post by paddle »
The same is at CmdSketcherConstrainPerpendicular::applyConstraint
openBrain
Post by openBrain »
adrianinsaval wrote: Thu Jan 20, 2022 3:25 pm I won't pretend to understand sketcher code but are you sure it's not needed? The comment mentions the block constraint, is this how external geometry are called in the code? or is this if relevant for the (GUI) block constraint?
A naked eye is sometime needed. :) You're totally right. There is no issue deleting the check regarding external geometries, but Block constraints aren't handled by the selection and still need to be checked. I'll have a deeper look.
C++ (compared to C) not only has pointer to reference a variable, but also so called 'reference' (which roughly is a non-null pointer to a known type variable). It is denoted with an ampersand '&' in the function prototype but right that when using it, you hardly see the difference with a 'by value' argument. See function prototype :
void getIdsFromName(const std::string &name, const Sketcher::SketchObject* Obj, int &GeoId, Sketcher::PointPos &PosId);
adrianinsaval
thanks for the explanation! As you have probably guessed I learned some C years ago and was told C++ added a bunch of fancy things but was essentially the same, not sure to what extent that's true but many of my assumptions still come from (also limited) C knowledge
openBrain
Post by openBrain »
https://github.com/FreeCAD/FreeCAD/pull/5402
EDIT : Doing so I saw that Perpendicular constraint doesn't support the vertex/vertex mode in continuous mode.
Will fix it when above PR is merged. ;)
openBrain wrote: Thu Jan 20, 2022 4:54 pm Doing so I saw that Perpendicular constraint doesn't support the vertex/vertex mode in continuous mode.
That sheds some light on the usage of this mode, because I think that is the most frequently used variant of the perpendicular constraint. Or perhaps this mode is used only by the smart guys, who know about Polyline and the power of the Mystery M.
