Merge to Master Protocol re CI Checks
wandererfan
Post by wandererfan »
I have some PRs that are waiting for CI check runs. Do we still require the check runs before merging?
chennes
Re: Merge to Master Protocol re CI Checks
Post by chennes »
"Require" is probably too strong a term -- because Bernd has to manually kick off the CI runs on PRs, and he's on holiday right now, there's a backlog: if you feel like your PR is ready to go, and it passes your tests locally, I think you can go ahead and merge it. If you are just looking for a run of the test suite on another system I'd be happy to run your PRs locally, just tell me what sort of system you want them tested on.
Chris Hennes
Pioneer Library System
wandererfan
chennes wrote: Fri Jan 21, 2022 3:49 pm
Thanks for the information. The changes are mostly on the Gui side, so they won't really be exercised by the test suite.
