[FIXED] Ticket #4835 - Periodic BSpline Control Polygon not Closing Anymore
louisgag
Post by louisgag »
Hello,
I hope I did not mix something up in the settings, but my Periodic B-Splines are not closing properly anymore and I suspect it has to do with one of the latest daily updates (stopped working about a week ago).
Any Periodic BSpline I create leaves the last member of the control polygon out, as in the picture
The sketch also has a missing coincidence where the spline should close.
Here's the link the the related issue: https://tracker.freecadweb.org/view.php?id=4835 and an example FreeCAD file is attached.
OS: Ubuntu 20.04.3 LTS (ubuntu:GNOME/ubuntu)
Version: 0.20.
Branch: unknown
Hash: 4fb91e4f02636fdb69eb8471dbbbe154dc932872
Python version: 3.8.10
Qt version: 5.12.8
Coin version: 4.0.0
OCC version: 7.5.2
Locale: C/Default (C)
Can someone confirm this bug?
periodicSplineNotClosing.FCStd
(4.49 KiB) Downloaded 32 times
Reason: Added [Fixed] to thread title
Re: Periodic BSpline Control Polygon not Closing Anymore
The missing coincidence is only indicating that there is no coincidence constraint. This was already in 0.18 so.
And the missing line may not really be an issue. If I open the file in 0.20.26155 the fourth line is shown.
adrianinsaval
Post by adrianinsaval »
perhaps abdullah's changes to viewprovider have something to do with this?
GeneFC
Post by GeneFC »
The fourth line on the right side line shows in 0.20.26761 and does not show in 0.20.26858. I don't have any versions between those numbers.
Gene
Re: Ticket #4835 - Periodic BSpline Control Polygon not Closing Anymore
Post by Kunda1 »
abdullah wrote::bell:
CC @Abdullah
abdullah
Post by abdullah »
Kunda1 wrote: Sat Feb 05, 2022 2:04 am
CC @Abdullah
Thanks for the ping.
git commit 7aefd2366f182c09683fc696f38c6a57c1b8fa15
Re: [FIXED] Ticket #4835 - Periodic BSpline Control Polygon not Closing Anymore
Post by Kunda1 »
Nice. I've closed the ticket.
@louisgag can you retest?
louisgag
Post by louisgag »
I've just tested with the daily package and the control polygon closes properly.
(The missing coincidence remains, but it doesn't prevent the extrusion and is not an issue, as pointed above by chrisb)
Thanks for having fixed it.
