[solved] Type conversion problem: TechDraw::BaseGeom* versus TechDraw::BaseGeomPtr
edi
Post by edi »
Hi everybody,
I have the two functions:
void BaseGeom::intersectionLL(TechDraw::BaseGeomPtr geom1,  TechDraw::BaseGeomPtr geom2, std::vector<Base::Vector3d>& interPoints)
std::vector<Base::Vector3d> BaseGeom::intersection(TechDraw::BaseGeomPtr geom2)
	std::vector<Base::Vector3d> interPoints;
	intersectionLL(this, geom2, interPoints); // <-- compiler message
TechDraw::BaseGeomPtr geom1 = ...
TechDraw::BaseGeomPtr geom2 = ...
interPoints = geom1->intersection(geom2);
The compiler returns the message:
error: cannot convert ‘TechDraw::BaseGeom*’ to ‘TechDraw::BaseGeomPtr’ {aka ‘std::shared_ptr<TechDraw::BaseGeom>’}
The compiler message occures, because "this" is of type TechDraw::BaseGeom*, it should be TechDraw::BaseGeomPtr.
How can I convert "this" ?
Re: Type conversion problem: TechDraw::BaseGeom* versus TechDraw::BaseGeomPtr
Post by wmayer »
You have to make BaseGeom a subclass of std::enable_shared_from_this. Then inside your function you can use shared_from_this().
Currently BaseGeom is declared in Geometry.h with
class TechDrawExport BaseGeom
and you have to replace this line with
class TechDrawExport BaseGeom : public std::enable_shared_from_this<BaseGeom>
edi
Post by edi »
Thank you for the very quick answer. It was the solution.
