GeomBSplineCurve::interpolate
Gift
Post by Gift »
Null vectors from GeomBSplineCurve::interpolate will ignored, or how I disable the load function?
Gift
Re: GeomBSplineCurve::interpolate
Post by Gift »
Ok, all are in release stress, or the weather is too good. Can I submit this as PR? Maybe is this attractive.
jnxd
Post by jnxd »
Gift wrote: Sun May 22, 2022 6:07 pm Ok, all are in release stress, or the weather is too good. Can I submit this as PR? Maybe is this attractive.
It's not completely clear what this method does. Could you add comments and documentation?
Gift
Post by Gift »
jnxd wrote: Sun May 22, 2022 7:27 pm It's not completely clear what this method does. Could you add comments and documentation?
Thanks for the response. I'm add a description to header and make periodic selectable, See the same commit. Untested example:
std::vector<gp_Pnt> pts { {0.,0.,0.}, {0.,5.,2,}, {0.,10.,3.}, {0.,4.,4.}};
Part::GeomBSplineCurve bsp = Part::GeomBSplineCurve();
bsp.interpolate(pts);
Part::Feature *obj = (Part::Feature *)Document->addObject("Part::Feature", "Spline");
obj->Shape.setValue(bsp.toShape());
The idea behind this is to use already existing structure and do not implement the same things again. (Maintenance-friendly)
