[fixed] CMake option DESIGNER_PLUGIN_LOCATION has no effect
uwestoehr
Post by uwestoehr »
Today I found out by chance how easy it is to build the Qt designer plugin.
While documenting this, I noticed that the path I set in the CMake option DESIGNER_PLUGIN_LOCATION is ignored.
When I set the CMake option BUILD_DESIGNER_PLUGIN the plugin is correctly compiled in the path
~build folder\src\Tools\plugins\widget\Release
But not transferred to the DESIGNER_PLUGIN_LOCATION path, also not when compiling the INSTALL build target.
Can anybody confirm this?
Founder
Re: CMake option DESIGNER_PLUGIN_LOCATION ha sno effect
Post by wmayer »
It's because of this: https://cmake.org/cmake/help/latest/com ... stall.html
The install() command is mainly needed on Linux and there it works as expected. On Windows, however, the RUNTIME target must be set.
I will push a fix soon...
uwestoehr
Post by uwestoehr »
wmayer wrote: Mon May 23, 2022 3:19 pm git commit a4480b4ba7
Thanks!
