spaceball again and again 2022
zawier
Post by zawier »
Hi Everyone,
I'm new on that forum as well as in FreeCad world :)
Currently I'm using Garuda Linux (which is based on Arch).
Installed a Freecad on it and wanted to force my 3Dconnexion manipulator work together.
Unfortunatelly Pacman (default package manager) doesn't include spacenavd. That's why tried to install it manually as suggested bellow:
https://wiki.freecadweb.org/3Dconnexion_input_devices
Ewerything go ok until:
sudo make install
Which returns :
mkdir -p /usr/local/bin
cp spacenavd /usr/local/bin/spacenavd
cp ./spnavd_ctl /usr/local/bin/spnavd_ctl
cd . && ./setup_init --no-install
--- Spacenavd installation complete ---
To have spacenavd start automatically at bootup, you must add an appropriate
init script. Refer to your system's manual for details on how to do that.
An example init script is available in the spacenavd source directory.
If you wish to attempt and install an init script automatically, run ./setup_init
Which is simmilar to an old topic:
pperisin wrote: Sun Mar 11, 2012 8:33 pm here is what I get on half of the wiki process:
barba@linux-3dil:~/Downloads> ls
libspnav-0.2.2  libspnav-0.2.2.tar.gz  spacenavd-0.5  spacenavd-0.5.tar.gz  spnavcfg-0.2.1  spnavcfg-0.2.1.tar.gz
barba@linux-3dil:~/Downloads> cd spacenavd-0.5/
barba@linux-3dil:~/Downloads/spacenavd-0.5> ls
AUTHORS  Changelog  configure  COPYING  doc  init_script  Makefile.in  README  setup_init  spnavd_ctl  src
barba@linux-3dil:~/Downloads/spacenavd-0.5> ./configure
configuring spacenavd - 0.5
  prefix: /usr/local
  optimize for speed: yes
  include debugging symbols: yes
  x11 communication method: yes
  use hotplug: yes
creating Makefile ...
creating config.h
Done. You can now type make (or gmake) to compile spacenavd.
barba@linux-3dil:~/Downloads/spacenavd-0.5> make
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/client.c -o src/client.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/proto_unix.c -o src/proto_unix.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/proto_x11.c -o src/proto_x11.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/dev_linux.c -o src/dev_linux.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/dev_serial.c -o src/dev_serial.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/cfgfile.c -o src/cfgfile.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/xdetect_linux.c -o src/xdetect_linux.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/event.c -o src/event.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/spnavd.c -o src/spnavd.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/serial/sball.c -o src/serial/sball.o
gcc -pedantic -Wall -g -O3 -fno-strict-aliasing -I./src -c src/serial/sballserial.c -o src/serial/sballserial.o
gcc -o spacenavd src/client.o src/proto_unix.o src/proto_x11.o src/dev_linux.o src/dev_serial.o src/cfgfile.o src/xdetect_linux.o src/event.o src/spnavd.o src/serial/sball.o src/serial/sballserial.o -lX11
barba@linux-3dil:~/Downloads/spacenavd-0.5> sudo make install
root's password:
install -d /usr/local/bin
install -m 755 spacenavd /usr/local/bin/spacenavd
install -m 755 ./spnavd_ctl /usr/local/bin/spnavd_ctl
barba@linux-3dil:~/Downloads/spacenavd-0.5> ./setup_init
You're either using a non-standard init or this detection failed.
You'll have to setup your init, to start spacenavd, manually.
barba@linux-3dil:~/Downloads/spacenavd-0.5> sudo ./setup_init
barba@linux-3dil:~/Downloads/spacenavd-0.5> /etc/init.d/spacenavd start
bash: /etc/init.d/spacenavd: No such file or directory
So 10 years after and we have the same problem? Is that correct?
Any idea how to fix that?
Best regards
PrzemoF
Re: spaceball again
Post by PrzemoF »
Welcome to the FreeCAD forum!
The installation didn't show any problems, so you seem to have it installed. Did you test it outside of FreeCAD? The old post was showing some errors. Your compilation doesn't show any unless you trimmed the output.
That might help you: http://spacenav.sourceforge.net/faq.html
zawier
Re: spaceball again
Post by zawier »
Przemo you are right:
PrzemoF wrote: Mon May 30, 2022 7:45 pm you seem to have it installed.
╭─zawier@zawier in /usr/local/bin🔒 as 🧙 took 623ms
✦ [🔴] × spacenavd -V
spacenavd v1.0
What do you mean by testing outside?
No I haven't trimmed shell output, that's it.
Somehow my spacenav isn't added to systemctl and here don't know how to enabe it.
Of course I've tried :
sudo systemctl enable spacenavd
But it doesn't recoginize I'm guessing:
╭─zawier@zawier in ~/Pobrane/spacenavd-1.0 took 1ms
╰─λ sudo systemctl enable spacenavd
[sudo] hasło użytkownika zawier:
Failed to enable unit: Unit file spacenavd.service does not exist.
M4x
Re: spaceball again
Post by M4x »
Welcome to the forum! A separate thread would've been more appropriate I think.
Which input device are you using? Your full FreeCAD version information would be nice too, please have a look at https://forum.freecadweb.org/viewtopic.php?f=3&t=2264
spacenavd just released version 1.0 (2022-04-01) and they've changed a lot! Please remove your current version using your packet manager and install the 1.0 version manually.
You'll need spacenavd, libnavd and optionally spnavcfg (haven't used the later yet but I had a brief look at it yesterday and I'm definitely going to install that one!)
spacenavd
https://github.com/FreeSpacenav/spacenavd
https://github.com/FreeSpacenav/spacenavd/releases
libnav
https://github.com/FreeSpacenav/libspnav/
https://github.com/FreeSpacenav/libspnav/releases
spnavcfg
https://github.com/FreeSpacenav/spnavcfg/
https://github.com/FreeSpacenav/spnavcfg/releases
After you've installed everything, make sure the input device is working by using one of the examples provided by libnav:
If you're not sure if spacenavd is set up correctly and works with your device, a good first step is to try and run the "simple" example program which comes with libspnav. It builds into two variants: simple_af_unix and simple_x11, which is helpful for testing both supported communication protocols. If either or both fail to work, there's something wrong with your setup.
https://github.com/FreeSpacenav/spacena ... leshooting
Thank you!
edit:
While I've written my reply, @zawier made another post. Which version are you using? From your first post I thought it was something like 0.5. Now I'm seeing 1.0. Please make sure that only one version is installed and make clear what you've done and what you've tested so far.
zawier
Re: spaceball again
Post by zawier »
Hi M4x!
So lets start from top of your list:
M4x wrote: Mon May 30, 2022 8:05 pm Which input device are you using?
Exactly that one: https://3dconnexion.com/us/product/spacemouse-compact/
FreeCAD info :
OS: Garuda Linux (KDE/plasma)
Version: 0.19.24415 (Git)
Branch: makepkg
Hash: 476ecf091941bead59b14e44afa6064d5a66afa3
Python version: 3.10.4
Qt version: 5.15.3
Coin version: 4.0.1
OCC version: 7.5.3
Locale: Polish/Poland (pl_PL)
M4x wrote: Mon May 30, 2022 8:05 pm spacenavd just released version 1.0
Yeap, exactly that version I compilled on my station.
M4x wrote: Mon May 30, 2022 8:05 pm You'll need spacenavd, libnavd
Got it:
spacenavd v1.0
╭─zawier@zawier in /usr/local/bin🔒 took 6ms
✦  ╰─λ pacman -Q libspnav
libspnav 1.0-1
M4x wrote: Mon May 30, 2022 8:05 pmspnavcfg
a such lib doesn't exists in arch repossitory .
M4x wrote: Mon May 30, 2022 8:05 pmPlease make sure that only one version is installed and make clear what you've done and what you've tested so far.
Yeap, I'm sure I have only one version of spacenavd installed.
What I have done so far? Not much I guess: checked systemclt service (failed), checked whether FreeCad see device (failed), checked if computer recognize my device (correct). What's more installed libs which you mentioned, except spnavcfg which in my case seams to be not needed (where I don't have planty of additional buttons).
Interesting thing is fact that long time ago (a few months) I succesfully installed spacenavd + libs and it was working out of the box. Right now I faced problems and that's why I've decived to ask for yours help.
M4x wrote: Mon May 30, 2022 8:05 pm simple_af_unix and simple_x11,
Ok, how to fired it up? :) I'd like to test it.
PrzemoF
Re: spaceball again
Post by PrzemoF »
"Also make sure to check out the example programs which come with libspnav: simple, cube, fly"
Look for them in the compiled code.
M4x
Re: spaceball again
Post by M4x »
Thank you for making use of the quote-function ;)
zawier wrote: Mon May 30, 2022 8:17 pm
Great, this is going to work.
zawier wrote: Mon May 30, 2022 8:17 pm FreeCAD info :
Perfect, thanks.
Like I've said, it's optional. But I think it's very valuable to adjust settings regarding the axis and overall behavior for example. You can use the config file too of course. I've posted the GitHub link previously.
Please try these examples from libnav:
  • simple_af_unix (test button input)
  • cube (test "joystick" input)
    Download the latest libspnav release from https://github.com/FreeSpacenav/libspnav/releases extract it somewhere, and change into that directory.
    run ./configure and then make in the libspnav directory to build libspnav
    change into the examples/simple directory, and run make to build the example program.
    finally run ./simple_af_unix
https://github.com/FreeSpacenav/spacena ... tton-names
It's the same for cube. Cube can be found in the folder cube instead of simple.
Founder
Re: spaceball again and again 2022
Post by wmayer »
zawier wrote: Mon May 30, 2022 6:30 pm Installed a Freecad on it and wanted to force my 3Dconnexion manipulator work together.
Does your FreeCAD installation link to the spacenav library as otherwise it's pointless. The best way to check this is by running
FreeCAD --log-file /tmp/freecad.log
and close it immediately again. Then open the file /tmp/freecad.log and search for the messages
Connected to spacenav daemon
or
Couldn't connect to spacenav daemon. Please ignore if you don't have a spacemouse.
If none of them appears then your FreeCAD build doesn't link the spacenav library. If the former message appears then it basically works and for the latter message there is probably a problem with the spacenav daemon.
Post by Kunda1 »
wmayer wrote: Tue May 31, 2022 8:43 am Couldn't connect to spacenav daemon. Please ignore if you don't have a spacemouse.
IIRC this wasn't backportrdnto 0.19 right? All the up-to-date spacemouse improvements are in v0.20dev
Founder
Post by wmayer »
Kunda1 wrote: Tue May 31, 2022 10:38 am IIRC this wasn't backportrdnto 0.19 right? All the up-to-date spacemouse improvements are in v0.20dev
It is also part of v0.19: https://github.com/FreeCAD/FreeCAD/blob ... ux.cpp#L51
