spacenavd - daemon is flooding syslog with messages
eajmarceau
Post by eajmarceau »
I am using 3dconnexion SpaceNavigator spaceball.
That is working correctly for me within both versions 19 and 20 of FreeCAD.
I had to look at my Linux system's syslog for an unrelated issue (disk drive flagged by SMART), I noticed something I did not expect: spacenavd is flooding my syslog with messages!
These messages are alternating groups of 2 types of messages.
total lines involved:
wc -l syslog = 24990
grep '3Dconnexion Space Navigator' syslog | wc -l = 9522 (x 2.5 = 23805 => 95% of log lines !!!
Elapsed Time:
Jun 13 19:18:29 Syslog entry (aprox)
Jun 13 22:42:46 Last log entry
=> 3h 24m
Date & Time for system boot are presented here as reference (syslog.1, log file roll-over):
42429 Jun 12 21:08:49 OasisMega1 systemd[1]: unattended-upgrades.service: Succeeded.
42430 Jun 13 19:18:18 OasisMega1 systemd[1]: Finished Remount Root and Kernel File Systems.
42431 Jun 13 19:18:18 OasisMega1 systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
First reference to spacenavd in syslog:
   55 Jun 13 19:18:37 OasisMega1 spacenavd[970]: failed to open config file /etc/spnavrc: No such file or directory. using defaults.
   56 Jun 13 19:18:46 OasisMega1 spacenavd[970]: failed to open X11 display ":0.0"
Group 1 (2-line sets; 26 sets):
   57 Jun 13 19:18:46 OasisMega1 spacenavd[970]: already using device: 3Dconnexion Space Navigator (/dev/input/event6)
   58 Jun 13 19:18:46 OasisMega1 spacenavd[970]: failed to find any supported devices
Next significant non-repeating grouping related to spacenavd:
  107 Jun 13 19:18:46 OasisMega1 spacenavd[970]: Spacenav daemon 0.6
  108 Jun 13 19:18:46 OasisMega1 spacenavd[970]: Device detection, parsing /proc/bus/input/devices
  109 Jun 13 19:18:47 OasisMega1 spacenavd[970]: found usb device [0:c626]: "3Dconnexion Space Navigator" (/dev/input/event6)
  110 Jun 13 19:18:47 OasisMega1 spacenavd[970]: adding device.
  111 Jun 13 19:18:47 OasisMega1 spacenavd[970]: device name: 3Dconnexion Space Navigator
  112 Jun 13 19:18:47 OasisMega1 spacenavd[970]:   Number of axes: 6
  113 Jun 13 19:18:47 OasisMega1 spacenavd[970]: using device: /dev/input/event6
  114 Jun 13 19:18:47 OasisMega1 spacenavd[970]: trying to open X11 display ":0.0"
  115 Jun 13 19:18:47 OasisMega1 spacenavd[970]:    XAUTHORITY=/root/.Xauthority
  116 Jun 13 19:18:47 OasisMega1 spacenavd[970]: waiting for the X socket file to appear
Group 2 (3-line sets; 27 sets):
  117 Jun 13 19:18:47 OasisMega1 spacenavd[970]: handle_hotplug called
  118 Jun 13 19:18:47 OasisMega1 spacenavd[970]: Device detection, parsing /proc/bus/input/devices
  119 Jun 13 19:18:47 OasisMega1 spacenavd[970]: found usb device [0:c626]: "3Dconnexion Space Navigator" (/dev/input/event6)
Transition set:
202 Jun 13 19:18:47 OasisMega1 spacenavd[970]: Device detection, parsing /proc/bus/input/devices
  203 Jun 13 19:18:47 OasisMega1 spacenavd[970]: found usb device [0:c626]: "3Dconnexialready using device: 3Dconnexion Space Navigator (/        dev/input/event6)
Restart repeat of Group 2 (2-line sets; 26 sets):
  204 Jun 13 19:18:47 OasisMega1 spacenavd[970]: failed to find any supported devices
  205 Jun 13 19:18:47 OasisMega1 spacenavd[970]: already using device: 3Dconnexion Space Navigator (/dev/input/event6)
etc. ... ad nauseum ...
22558 Jun 13 21:36:30 OasisMega1 spacenavd[970]: already using device: 3Dconnexion Space Navigator (/dev/input/event6)
22559 Jun 13 21:36:30 OasisMega1 spacenavd[970]: failed to find any supported devices
Group 3 (1-line transition set; single set):
22560 Jun 13 21:36:30 OasisMega1 spacenavd[970]: us/input/devices
Group 1 (3-line sets; 27 sets):
22561 Jun 13 21:36:30 OasisMega1 spacenavd[970]: found usb device [0:c626]: "3Dconnexion Space Navigator" (/dev/input/event6)
22562 Jun 13 21:36:30 OasisMega1 spacenavd[970]: handle_hotplug called
22563 Jun 13 21:36:30 OasisMega1 spacenavd[970]: Device detection, parsing /proc/bus/input/devices
Group 4 (3-line transition set; single set):
22640 Jun 13 21:36:30 OasisMega1 spacenavd[970]: handle_hotplug called
22641 Jun 13 21:36:30 OasisMega1 spacenavd[970]: Device detection, parsing /proc/bus/input/devices
22642 Jun 13 21:36:30 OasisMega1 spacenavd[970]: foalready using device: 3Dconnexion Space Navigator (/dev/input/event6)
Is there some way to put some sanity into the spacenavd daemon? An option switch for boot or configuration file?
NOTE: this is happening whether FreeCAD is running or not !!!
Python 3.9.13 | packaged by conda-forge | (main, May 27 2022, 17:07:55) [GCC 10.3.0] on linux
OS: Ubuntu 20.04.4 LTS (MATE/mate)
Version: 0.20.28993 (Git) AppImage
Branch: (HEAD detached at 6d92e53)
Hash: 6d92e532bcc31c99a0ab4c153ff00b6414b8f527
Python 3.9.13, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Installed mods:
  * Silk 521030960.0.0
  * workfeature
  * Curves 0.3.0
  * offline-documentation 1.0.0-alpha
  * nurbs
  * ImportNURBS
  * CurvedShapes 1.0.3
  * workfeature-macro
  * Pyramids-and-Polyhedrons
Messaging in syslog (coloured)
More messaging in syslog (coloured)
