Thanks. backported nowwandererfan wrote: ↑Sun Sep 11, 2022 4:27 pm Wrong spelling of leader line preference: http://github.com/FreeCAD/FreeCAD/commit/e28317f772
[Tracking] Backport commits to 0.20 branch
Re: [Tracking] Backport commits to 0.20 branch
https://github.com/FreeCAD/FreeCAD/pull/7507 contains the backport and was now merged.uwestoehr wrote: ↑Sun Sep 11, 2022 7:29 pmThanks. Yes, can you please make a separate PR directly for the 0-20 branch?marioalexis wrote: ↑Thu Aug 18, 2022 1:34 pm The fix is embedded with other changes, so it might not be accepted. In that case, I can split the request and solve the specific regression.
- wandererfan
encode Xml special characters in spreadsheet - git commit a85f751668
Thanks. I think i once asked if you can do the backport directly. In my opinion every developer should directly backport what he thinks is worth it. (This would also help me a bit, my spare time is very limited at the moment due to unforeseen issues and I currently only do some header work to relax before going to sleep (don't laugh )).wandererfan wrote: ↑Tue Oct 04, 2022 12:20 pm encode Xml special characters in spreadsheet - git commit a85f751668
I backported now.uwestoehr wrote: ↑Wed Oct 05, 2022 6:52 pmThanks. I think I once asked if you can do the backport directly. In my opinion every developer should directly backport what he thinks is worth it.wandererfan wrote: ↑Tue Oct 04, 2022 12:20 pm encode Xml special characters in spreadsheet - git commit a85f751668
I don't think that's a good idea, unless you're referring to certain "core" developers with ability to merge. Otherwise people can try to merge everything.
Maybe commit suggestions can come with PRs onto the 0.20 (or previous supported version) branch with the tag "[Backport]".
- wandererfan
Are there instructions somewhere on how to do this? I know how to push the "rebase and merge" button for master branch, but that is the extent of my expertise on Github.
Roughly you just have to checkout the (up-to-date) 0.20 branch, then 'git cherry-pick' the commits to be backported, and finally push the branch back.wandererfan wrote: ↑Thu Oct 06, 2022 1:28 pm Are there instructions somewhere on how to do this? I know how to push the "rebase and merge" button for master branch, but that is the extent of my expertise on Github.
- adrianinsaval
Note that if there were other developments in the affected files in master branch it might not be enough to just cherry pick commits but also to adapt the solution to the 0.20 codebase or also backport the previous changes, this shouldn't be a common occurrence though
