Help with git for testing Addon Manager
I'm writing some tests for the Addon Manager, and of course one of the things that I want to test is checking for updates. In the context of a unit test, what I need to do is check out some Addon at some past revision, and then make git think that rather than being in a detached head state, it is just out-of-date. Or something equivalent. Can anyone who is better at git than me give me some pointers to how to achieve something like that?
- adrianinsaval
Re: Help with git for testing Addon Manager
how about
git reset --hard {commit_hash}
To my knowledge, you can only achieve this in a branch.
When I try that, "git fetch" doesn't return anything, it acts like it is up-to-date.adrianinsaval wrote: ↑Tue Aug 09, 2022 7:28 pm how aboutCode: Select all
Is that a problem to use a branch for the test?
git checkout @^1 -B test_branch
- adrianinsaval
well fetching is not the correct way to check for updates, you need to compare the remote to the local checked out state, what if I run git fetch on an outdated addon? the checked out copy remains outdated but if I run git fetch again I'll get nothing.
git fetch would still return nothing so it's no different than git reset --hardopenBrain wrote: ↑Tue Aug 09, 2022 8:48 pm Is that a problem to use a branch for the test?Code: Select all
If you really want to have git fetch return something again I think you can do this:
git update-ref refs/remotes/origin/master refs/remotes/origin/master@{1}
Yeah, I wasn't sure if the original author had some particular reason to use fetch, though, so I didn't change it. I was hoping to test the code as-is before I did anymore refactoring, but it seems like that's not feasible, I am having to refactor just to enable testing! Oh well...
In git isn't one always technically on a branch? Anyway, that type of checkout lands you in a detached head state, doesn't it?openBrain wrote: ↑Tue Aug 09, 2022 8:48 pm Is that a problem to use a branch for the test?Code: Select all
Using which command?adrianinsaval wrote: ↑Tue Aug 09, 2022 8:53 pm you need to compare the remote to the local checked out state
Oh sorry -- although it does do a fetch every time, it's really looking at the output of git status to determine the up-to-date status. Nevertheless, if I specifically reset to a specific revision, git status returns nothing.
