[solved] Uninstall compiled FreeCAD in Linux
catman
Post by catman »
Probably a very trivial question but I failed to find a solution on the wiki or in this forum.
I downloaded and compiled a modified FreeCAD source with
 mkdir buld && cd build
 cmake .. && make
 sudo make install
The code installs to /usr/local/* and it works fine with the same settings than my installed AppImage.
Now I want to clean up and uninstall it again. I expected something like
 sudo make uninstall
which did not work. I did not see another target for that.
How do I unstall a self-compiled FreeCAD from /usr/local/*?
jnxd
Re: uninstall compiled FreeCAD in Linux
Post by jnxd »
Could you try any of the answers from this: https://stackoverflow.com/questions/143 ... rary-in-li? Fair warning I haven't tried it myself.
In the future you can set an "install prefix" in cmake (-DCMAKE_INSTALL_PREFIX) to tell make to install it there instead of in usr.
My latest (or last) project: B-spline Construction Project.
Founder
Post by wmayer »
catman wrote: Fri Aug 12, 2022 9:20 am How do I unstall a self-compiled FreeCAD from /usr/local/*?
https://stackoverflow.com/questions/414 ... -uninstall
https://gitlab.kitware.com/cmake/commun ... with-cmake
The suggested method is to run
xargs rm < install_manifest.txt
catman
Post by catman »
jnxd wrote: Sun Aug 14, 2022 2:06 am Could you try any of the answers from this: https://stackoverflow.com/questions/143 ... rary-in-li?
wmayer wrote: Sun Aug 14, 2022 8:42 am The suggested method is to run
Excellent. Thanks for your answers and also the links for further reading.
I needed sudo to remove the parts from the /usr/local.
xargs sudo rm < install_manifest.txt
But in your links was another gem: "checkinstall" makes a *.deb package from the built sources. Its an interactive script. Its great to distribute a local version for testing. Here is the use on Ubunut 22.04
 sudo apt install checkinstall                             # do once, if not installed
  cd ~/temp/freecad-master/build                     # or whereever the sources are
  cmake ..
  make
  sudo checkinstall                                                     # interactive
It asked a few questions and required to add some description. Default was OK for me, except I should have set a "Name" for the package, because thats needed to uninstall it again. The default name is "build".
I used this to install/uninstall it. The installation also went to /usr/local.
  sudo dpkg -i build_22020814-1_amd64.deb     # install
  sudo dpkg -r build                                             # remove
it takes a couple of minutes to build the package, because its single CPU only. Maybe there is a multi-CPU switch, but I did not find it.
