Addon Manager Developer Mode
Re: Addon Manager Developer Mode
Post by Kunda1 »
Thx chennes!
onekk
Post by onekk »
As a side note I have this warning:
Worker process check_for_python_package_updates_worker is taking a long time to stop...
And it blocks the exit from the session, that I start from a terminal using a script, forcing me to close the "terminal window" but FreeCAD window is closing correctly. If you need further infos feel free to ask.
It work correctly in:
OS: Artix Linux (openbox)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Locale: Italian/Italy (it_IT)
Installed mods:
  * Curves 0.5.8
But the error is present in:
Version: 0.21.30398 (Git)
Hash: b3dfdc568a92810449bf47bc73b6784d65dfa206
Python 3.10.6, Qt 5.15.4, Coin 4.0.0, Vtk 9.1.0, OCC 7.6.3
Installed mods:
  * test_wb
  * fcgear 1.0.0
  * Assembly4 0.12.4
  * toSketch 1.0.1
  * Curves 0.5.8
   * Help 1.0.3
I think that the culprit could be these multiple invocation of QtWebEngineProcess, taken from a:
ps ax
when FC "terminal window" is not closing, I invoke FC using a script that issue the 6875 command to launch my "conda-install" version.
 6875 ?        S      0:00 urxvt -T FreeCAD-launcher -e freecad
 6876 pts/3    Ssl+   1:34 freecad
 6893 pts/3    S+     0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 6894 pts/3    S+     0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 6909 pts/3    Sl+    0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 6946 pts/3    Sl+    0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 7065 pts/3    S+     0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/bin/python3
 7165 pts/3    Sl+    0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 7350 pts/3    Sl+    0:02 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
EDIT:
This the output of the same command after starting FC without trying to use the AddOn Manager.
8370 ?        S      0:00 urxvt -T FreeCAD-launcher -e freecad
 8371 pts/3    Ssl+   0:02 freecad
 8388 pts/3    S+     0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 8389 pts/3    S+     0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 8404 pts/3    Sl+    0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 8406 pts/3    Sl+    0:00 /home/carlo-arch/miniconda3/envs/fcenv-dev/libexec/QtWebEngineProces
 8455 pts/1    R+     0:00 ps ax
But it close correctly the "terminal windows" if I exit from FC
As a side note FC 0.20.1 is an AppImage.
Hope it help.
Regards
Carlo D.
- Various other stuffs.
chennes
Post by chennes »
Thanks, I have some time now I'll see if I can poke at that check_for_python_package_updates_worker problem now.
Chris Hennes
Pioneer Library System
chennes
Post by chennes »
I added a timeout to the pip process, can you let me know if this has an affect on your bug?
git commit 9e1ed4a68
Chris Hennes
onekk
Post by onekk »
chennes wrote: Wed Sep 21, 2022 7:54 pm ...
As soon conda-install is updated I will surely let you know.
If AddonManager could be made an AddOn itself or cloned in the user Mod dir, it will be more easy.
Regards.
Carlo D.
chennes
Post by chennes »
I've added a new metadata tag, <pythonmin>, that allows Addon developers to specify a minimum required version of Python. I've also added a scanning feature to the Addon Manager Developer Mode that uses the Vermin package to scan your addon and determine what it things is your required minimum version of Python based on the features you use. This tag will be ignored by older versions of FreeCAD, so it is safe to include in your package.xml metadata file.
Chris Hennes
mfraz74
Post by mfraz74 »
onekk wrote: Wed Sep 21, 2022 3:23 pm As a side note I have this warning:
Installed mods:
  * Curves 0.5.8
Installed mods:
  * test_wb
  * fcgear 1.0.0
  * Assembly4 0.12.4
  * toSketch 1.0.1
  * Curves 0.5.8
   * Help 1.0.3
ps ax
EDIT:
Hope it help.
Regards
Carlo D.
Also seeing this with
OS: Ubuntu 22.04.1 LTS (KDE/plasma)
Version: 0.21.30492 (Git) AppImage
Hash: b4578fb3eae842eb510a1bc055d07d369a67ce94
Installed mods:
  * sheetmetal 0.2.57
  * Manipulator 1.4.9
  * lattice2 1.0.0
  * fcgear 1.0.0
  * Curves 0.5.8
  * Assembly4 0.11.8
  * fasteners
  * A2plus 0.4.59d
  * ThreadProfile 1.84.0
  * Assembly3 0.11.3
  * VendorParts
If I click on the "Python dependencies.." button, FreeCAD will freeze and clicking close brings up the Application "freecad" is not responding.
Running from CLI:
1.12302 <asm3.main> init_gui.py(14): no solver backend found
pip took longer than 30 seconds to return results, giving up on itTraceback (most recent call last):
  File "/tmp/.mount_FreeCAPVl7Ys/usr/Mod/AddonManager/manage_python_dependencies.py", line 54, in run
    if check_for_python_package_updates():
  File "/tmp/.mount_FreeCAPVl7Ys/usr/Mod/AddonManager/manage_python_dependencies.py", line 64, in check_for_python_package_updates
    outdated_packages_stdout = call_pip(["list", "-o", "--path", vendor_path])
  File "/tmp/.mount_FreeCAPVl7Ys/usr/Mod/AddonManager/manage_python_dependencies.py", line 112, in call_pip
    raise Exception(proc.stderr.decode())
UnboundLocalError: local variable 'proc' referenced before assignment
chennes
Post by chennes »
Can you let me know if git commit 9b4183581 resolves the issue for you?
Chris Hennes
mfraz74
Post by mfraz74 »
chennes wrote: Mon Oct 03, 2022 9:31 pm Can you let me know if git commit 9b4183581 resolves the issue for you?
Installed mods:
  * sheetmetal 0.2.58
  * Manipulator 1.4.9
  * lattice2 1.0.0
  * fcgear 1.0.0
  * Curves 0.5.10
  * Assembly4 0.11.8
  * fasteners
  * A2plus 0.4.59d
  * Assembly3 0.11.3
  * VendorParts
Still not working, in the Addon Manager the last text it shows at the bottom is "Download icon for frame"
  File "/tmp/.mount_FreeCA508knG/usr/Mod/AddonManager/manage_python_dependencies.py", line 54, in run
  File "/tmp/.mount_FreeCA508knG/usr/Mod/AddonManager/manage_python_dependencies.py", line 64, in check_for_python_package_updates
  File "/tmp/.mount_FreeCA508knG/usr/Mod/AddonManager/manage_python_dependencies.py", line 112, in call_pip
chennes
Post by chennes »
That’s the same version, you will need to update before it works. At the very least the line number of the error will change.
Chris Hennes
