mr-miky
Posts: 13 Joined: Sat Sep 28, 2019 1:16 pm
Post
by mr-miky » Sat Dec 03, 2022 10:56 am
Strange, I have build up to 2 days ago. Check the double %global but I don't think it's due to that
from copr spec file:
%global bundled_zipios %{?_with_bundled_zipios: 1} %{?!_with_bundled_zipios: 1}
# Some configuration options for other environments
# rpmbuild --with=bundled_zipios: use bundled version of zipios++
# rpmbuild --without=bundled_pycxx: don't use bundled version of pycxx
%global bundled_pycxx %{?_without_bundled_pycxx: 0} %{?!_without_bundled_pycxx: 1}
# rpmbuild --without=bundled_smesh: don't use bundled version of Salome's Mesh
%global bundled_smesh %{?_without_bundled_smesh: 0} %{?!_without_bundled_smesh: 1}
mr-miky on Sat Dec 03, 2022 1:15 pm, edited 1 time in total.
mr-miky
Post
by mr-miky » Sat Dec 03, 2022 11:45 am
started mock 30 minutes ago and ends with error not due to zipios++
**** ERROR:
Plugins not caught by regexp: cmake libgmock.so libgmock.so.1.12.1 libgmock_main.so libgmock_main.so.1.12.1 libgtest.so libgtest.so.1.12.1 libgtest_main.so libgtest_main.so.1.12.1 pkgconfig
Plugins in /usr/lib64/freecad/lib do not exist in
specfile %{plugins} macro. Please add these to
%{plugins} macro at top of specfile and rebuild.
+ exit 1
I do not understand it seems to me that the last 2 nightly have this problem
mr-miky
Post
by mr-miky » Sat Dec 03, 2022 1:09 pm
from your spec file:
%global bundled_zipios %{?_with_bundled_zipios: 1} %{?!_with_bundled_zipios: 0}
the second zipios++ %global override the first !!
Obviously in this way the problem of Zipios++ remains
Given the sec file that is on copr I think you had already gone beyond this problem
mr-miky
Post
by mr-miky » Sun Dec 04, 2022 1:25 pm
After a fair number of compilation attempts, it seems that the problem is related to the fact that test parts of the code are compiled.
%endif
-DPACKAGE_WCREF="%{release} (Git)" \
-DPACKAGE_WCURL="git://github.com/%{github_name}/FreeCAD.git master" \
make fc_version
add line -DBUILD_TEST=FALSE
%endif
-DBUILD_TEST=FALSE \
make fc_version
mr-miky
Post
by mr-miky » Sun Dec 04, 2022 1:50 pm
mr-miky wrote: ↑ Sun Dec 04, 2022 1:25 pm
%endif
make fc_version
%endif
make fc_version
mr-miky
Post
by mr-miky » Sun Dec 04, 2022 8:28 pm
Ok now it works.
The SPEC file is as follows:
# This package depends on automagic byte compilation
# https://fedoraproject.org/wiki/Changes/No_more_automagic_Python_bytecompilation_phase_3
%global py_bytecompile 1
# Setup python target for shiboken so the right cmake file is imported.
%global py_suffix %(%{__python3} -c "import sysconfig; print(sysconfig.get_config_var('SOABI'))")
# Maintainers: keep this list of plugins up to date
# List plugins in %%{_libdir}/%{name}/lib, less '.so' and 'Gui.so', here
%global plugins Fem FreeCAD PathApp Image Import Inspection Mesh MeshPart Part Points Raytracing ReverseEngineering Robot Sketcher Start Web PartDesignGui _PartDesign Path PathGui Spreadsheet SpreadsheetGui area DraftUtils DraftUtils libDriver libDriverDAT libDriverSTL libDriverUNV libE57Format libMEFISTO2 libSMDS libSMESH libSMESHDS libStdMeshers Measure TechDraw TechDrawGui libarea-native Surface SurfaceGui PathSimulator
#Hack to force zipios
# Prevent RPM from doing its magical 'build' directory for now
%global __cmake_in_source_build 0
# See FreeCAD-master/src/3rdParty/salomesmesh/CMakeLists.txt to find this out.
%global bundled_smesh_version 7.7.1.0
# Some plugins go in the Mod folder instead of lib. Deal with those here:
%global mod_plugins Mod/PartDesign
%define name freecad
%define github_name FreeCAD
%define branch master
Epoch: 1
Version: 0.21
Release: pre_31201%{?dist}
Summary: A general purpose 3D CAD modeler
Group: Applications/Engineering
License: LGPLv2+
URL: http://www.freecadweb.org/
Source0: https://github.com/%{github_name}/FreeCAD/archive/%{branch}.tar.gz
# Utilities
BuildRequires: cmake gcc-c++ gettext dos2unix
BuildRequires: doxygen swig graphviz
BuildRequires: gcc-gfortran
BuildRequires: desktop-file-utils
BuildRequires: git
# Development Libraries
BuildRequires: Coin4-devel
%if 0%{?fedora} < 35
BuildRequires: Inventor-devel
%endif
BuildRequires: opencascade-devel
BuildRequires: boost-devel
BuildRequires: boost-python3-devel
BuildRequires: eigen3-devel
BuildRequires: freeimage-devel
BuildRequires: libXmu-devel
# For appdata
%if 0%{?fedora}
BuildRequires: libappstream-glib
%endif
BuildRequires: libglvnd-devel
BuildRequires: libicu-devel
BuildRequires: libkdtree++-devel
BuildRequires: libspnav-devel
%if 0%{?fedora} < 37
BuildRequires: libusb-devel
%else
BuildRequires: libusb1-devel
%endif
BuildRequires: med-devel
BuildRequires: mesa-libEGL-devel
BuildRequires: mesa-libGLU-devel
BuildRequires: netgen-mesher-devel
BuildRequires: netgen-mesher-devel-private
BuildRequires: python3-pivy
BuildRequires: openmpi-devel
BuildRequires: pcl-devel
BuildRequires: pyside2-tools
BuildRequires: python3-devel
BuildRequires: python3-matplotlib
%if ! %{bundled_pycxx}
BuildRequires: python3-pycxx-devel
%endif
BuildRequires: python3-pyside2-devel
BuildRequires: python3-shiboken2-devel
BuildRequires: qt5-qtwebengine-devel
BuildRequires: qt5-qtwebkit-devel
BuildRequires: qt5-qtsvg-devel
BuildRequires: qt5-qttools-static
BuildRequires: qt5-qtxmlpatterns-devel
%if ! %{bundled_smesh}
BuildRequires: smesh-devel
%endif
BuildRequires: tbb-devel
BuildRequires: vtk-devel
BuildRequires: xerces-c
BuildRequires: xerces-c-devel
%if ! %{bundled_zipios}
BuildRequires: zipios++-devel
%endif
BuildRequires: zlib-devel
# Packages separated because they are noarch, but not optional so require them
# here.
Requires: %{name}-data = %{epoch}:%{version}-%{release}
# Obsolete old doc package since it's required for functionality.
Obsoletes: %{name}-doc < 0.13-5
Requires: hicolor-icon-theme
Requires: python3-collada
Requires: qt5-assistant
%if %{bundled_smesh}
Provides: bundled(smesh) = %{bundled_smesh_version}
%endif
%if %{bundled_pycxx}
Provides: bundled(python-pycxx)
%endif
Recommends: python3-pysolar
# plugins and private shared libs in %%{_libdir}/freecad/lib are private;
# prevent private capabilities being advertised in Provides/Requires
%define plugin_regexp /^\\\(libFreeCAD.*%(for i in %{plugins}; do echo -n "\\\|$i\\\|$iGui"; done)\\\)\\\(\\\|Gui\\\)\\.so/d
%{?filter_setup:
%filter_provides_in %{_libdir}/%{name}/lib
%filter_from_requires %{plugin_regexp}
%filter_from_provides %{plugin_regexp}
%filter_provides_in %{_libdir}/%{name}/Mod
%filter_requires_in %{_libdir}/%{name}/Mod
%filter_setup
%description
FreeCAD is a general purpose Open Source 3D CAD/MCAD/CAx/CAE/PLM modeler, aimed
directly at mechanical engineering and product design but also fits a wider
range of uses in engineering, such as architecture or other engineering
specialities. It is a feature-based parametric modeler with a modular software
architecture which makes it easy to provide additional functionality without
modifying the core system.
%package data
Summary: Data files for FreeCAD
BuildArch: noarch
Requires: %{name} = %{epoch}:%{version}-%{release}
%description data
%prep
%autosetup -p1 -n FreeCAD-%{branch}
# Remove bundled pycxx if we're not using it
rm -rf src/CXX
%endif
rm -rf src/zipios++
#sed -i "s/zipios-config.h/zipios-config.hpp/g" \
# src/Base/Reader.cpp src/Base/Writer.h
%endif
# Fix encodings
dos2unix -k src/Mod/Test/unittestgui.py \
ChangeLog.txt \
data/License.txt
# Removed bundled libraries
%build
rm -rf build && mkdir build && cd build
# Deal with cmake projects that tend to link excessively.
CXXFLAGS='-Wno-error=cast-function-type'; export CXXFLAGS
LDFLAGS='-Wl,--as-needed -Wl,--no-undefined'; export LDFLAGS
%if 0%{?fedora} > 27
%define MEDFILE_INCLUDE_DIRS %{_includedir}/med/
%else
%endif
%cmake \
-DCMAKE_INSTALL_PREFIX=%{_libdir}/%{name} \
-DCMAKE_INSTALL_DATADIR=%{_datadir}/%{name} \
-DCMAKE_INSTALL_DOCDIR=%{_docdir}/%{name} \
-DCMAKE_INSTALL_INCLUDEDIR=%{_includedir} \
-DRESOURCEDIR=%{_datadir}/%{name} \
-DFREECAD_USE_EXTERNAL_PIVY=TRUE \
-DFREECAD_USE_PCL=TRUE \
-DBUILD_QT5=ON \
-DSHIBOKEN_INCLUDE_DIR=%{_includedir}/shiboken2 \
-DSHIBOKEN_LIBRARY=-lshiboken2.%{py_suffix} \
-DPYTHON_SUFFIX=.%{py_suffix} \
-DPYSIDE_INCLUDE_DIR=/usr/include/PySide2 \
-DPYSIDE_LIBRARY=-lpyside2.%{py_suffix} \
-DPYTHON_EXECUTABLE:FILEPATH=/usr/bin/python3 \
-DMEDFILE_INCLUDE_DIRS=%{MEDFILE_INCLUDE_DIRS} \
-DOpenGL_GL_PREFERENCE=GLVND \
-DCOIN3D_INCLUDE_DIR=%{_includedir}/Coin4 \
-DCOIN3D_DOC_PATH=%{_datadir}/Coin4/Coin \
-DUSE_OCC=TRUE \
-DFREECAD_USE_EXTERNAL_SMESH=TRUE \
-DSMESH_FOUND=TRUE \
-DSMESH_INCLUDE_DIR=%{_includedir}/smesh \
-DSMESH_DIR=`pwd`/../cMake \
%endif
-DFREECAD_USE_EXTERNAL_ZIPIOS=TRUE \
%endif
-DPYCXX_INCLUDE_DIR=$(pkg-config --variable=includedir PyCXX) \
-DPYCXX_SOURCE_DIR=$(pkg-config --variable=srcdir PyCXX) \
%endif
make fc_version
for I in src/Build/Version.h src/Build/Version.h.out; do
sed -i 's,FCRevision \"Unknown\",FCRevision \"%{release} (Git)\",' $I
sed -i 's,FCRepositoryURL \"Unknown\",FCRepositoryURL \"git://github.com/FreeCAD/FreeCAD.git master\",' $I
done
%{make_build}
%install
cd build
%make_install
# Symlink binaries to /usr/bin
mkdir -p %{buildroot}%{_bindir}
ln -s ../%{_lib}/%{name}/bin/FreeCAD %{buildroot}%{_bindir}/FreeCAD
ln -s ../%{_lib}/%{name}/bin/FreeCADCmd %{buildroot}%{_bindir}/FreeCADCmd
mkdir %{buildroot}%{_metainfodir}/
mv %{buildroot}%{_libdir}/%{name}/share/metainfo/* %{buildroot}%{_metainfodir}/
mkdir %{buildroot}%{_datadir}/applications/
mv %{buildroot}%{_libdir}/%{name}/share/applications/* %{buildroot}%{_datadir}/applications/
mkdir -p %{buildroot}%{_datadir}/thumbnailers/
mv %{buildroot}%{_libdir}/%{name}/share/thumbnailers/* %{buildroot}%{_datadir}/thumbnailers/
mkdir -p %{buildroot}%{_datadir}/icons/hicolor/scalable/
mv %{buildroot}%{_libdir}/%{name}/share/icons/hicolor/scalable/* %{buildroot}%{_datadir}/icons/hicolor/scalable/
mkdir -p %{buildroot}%{_datadir}/pixmaps/
mv %{buildroot}%{_libdir}/%{name}/share/pixmaps/* %{buildroot}%{_datadir}/pixmaps/
mkdir -p %{buildroot}%{_datadir}/mime/packages/
mv %{buildroot}%{_libdir}/%{name}/share/mime/packages/* %{buildroot}%{_datadir}/mime/packages/
pushd %{buildroot}%{_libdir}/%{name}/share/
rmdir metainfo/
rmdir applications/
rm -rf mime
rm -rf icons
popd
# Remove obsolete Start_Page.html
rm -f %{buildroot}%{_docdir}/%{name}/Start_Page.html
# Belongs in %%license not %%doc
#No longer present?
#rm -f %{buildroot}%{_docdir}/freecad/ThirdPartyLibraries.html
# Remove header from external library that's erroneously installed
rm -f %{buildroot}%{_libdir}/%{name}/include/E57Format/E57Export.h
# Bug maintainers to keep %%{plugins} macro up to date.
# Make sure there are no plugins that need to be added to plugins macro
new_plugins=`ls %{buildroot}%{_libdir}/%{name}/%{_lib} | sed -e '%{plugin_regexp}'`
if [ -n "$new_plugins" ]; then
echo -e "\n\n\n**** ERROR:\n" \
"\nPlugins not caught by regexp: " $new_plugins \
"\n\nPlugins in %{_libdir}/%{name}/lib do not exist in" \
"\nspecfile %%{plugins} macro. Please add these to" \
"\n%%{plugins} macro at top of specfile and rebuild.\n****\n" 1>&2
exit 1
fi
# Make sure there are no entries in the plugins macro that don't match plugins
for p in %{plugins}; do
if [ -z "`ls %{buildroot}%{_libdir}/%{name}/%{_lib}/$p*.so`" ]; then
set +x
"\nExtra entry in %%{plugins} macro with no matching plugin:" \
"'$p'.\n\nPlease remove from %%{plugins} macro at top of" \
"\nspecfile and rebuild.\n****\n" 1>&2
exit 1
fi
done
%check
desktop-file-validate \
%{buildroot}%{_datadir}/applications/org.freecadweb.FreeCAD.desktop
%{?fedora:appstream-util validate-relax --nonet \
%{buildroot}/%{_metainfodir}/*.appdata.xml}
%post
/bin/touch --no-create %{_datadir}/icons/hicolor &>/dev/null || :
/usr/bin/update-desktop-database &> /dev/null || :
/usr/bin/update-mime-database %{_datadir}/mime &> /dev/null || :
%postun
if [ $1 -eq 0 ] ; then
/usr/bin/gtk-update-icon-cache %{_datadir}/icons/hicolor &>/dev/null || :
fi
%posttrans
/usr/bin/gtk-update-icon-cache %{_datadir}/icons/hicolor/scalable/apps &>/dev/null || :
%files
%license data/License.txt
%doc ChangeLog.txt
%exclude %{_docdir}/%{name}/%{name}.*
%exclude %{_docdir}/%{name}/ThirdPartyLibraries.html
%{_bindir}/*
%{_metainfodir}/*
%dir %{_libdir}/%{name}
%{_libdir}/%{name}/bin/
%{_libdir}/%{name}/Mod/
%{_libdir}/%{name}/Ext/
%{_datadir}/applications/*
%{_datadir}/icons/hicolor/scalable/*
%{_datadir}/pixmaps/*
%{_datadir}/mime/packages/*
%{_datadir}/thumbnailers/*
%files data
%{_datadir}/%{name}/
%{_docdir}/%{name}/LICENSE.html
I wasted a lot of time because I edited the spec file, I gave rpmbuild -bs freecad.spec and then I gave mock the wrong rpms to compile.
Schermata a 2022-12-05 10-24-34.png (132.58 KiB) Viewed 720 times
mr-miky
Post
by mr-miky » Mon Dec 05, 2022 6:56 pm
I did a search in the sources to see where libusb is used and found nothing.
I checked the spec file of freecad 0.20 distributed by fedora and there is no trace of libusb-devel among the BuildRequires.
I tried to delete it from BuildRequires and everything is completed even without libusb-devel.
%else
%endif
PrzemoF
Posts: 3520 Joined: Fri Jul 25, 2014 4:52 pm
Post
by PrzemoF » Wed Dec 07, 2022 7:40 pm
Thank you for all the hard work! The test build went fine and I'll be submitting a commit to the master branch soon to revive the COPR builds.
