Loft BOPAlgo.SelfIntersect error
grandcross
Post by grandcross »
Simply put, the Loft is generating errors I'm not sure I can fix. Here's what I'm doing:
Generate the shape of a fin root. Generate a shape for the fin tip. Create a solid loft and you have a fin. This works well for many shapes, but when I try it with an airfoil it generates self intersect errors.
I've included a macro which shows the problem. Open an empty project and run the macro. It will show a root chord outline, a fin chord outline, and the lofted fin offset so everything is visible. Switch to the Part workspace, select them all, and select Check Geometry from the Part menu. It will show you the part has errors even though the root and tip chords are fine.
I know a loft is a complex operation, but is this something I just have to live with? Is there anything I can do to fix it?
OS: Windows 10 Version 2009
Version: 0.20.29177 (Git)
Branch: releases/FreeCAD-0-20
Installed mods:
  * 3D_Printing_Tools
  * A2plus 0.4.59c
  * Assembly3 0.11.3
  * Assembly4 0.12.4
  * fasteners 0.4.12
  * fcgear 1.0.0
  * GDML 2.0.0
  * kicadStepUpMod 10.15.1
  * LCInterlocking
  * parts_library
  * Rocket 2.8.2
LoftError.FCMacro
(1.89 KiB) Downloaded 13 times
onekk
Re: Loft BOPAlgo.SelfIntersect error
Post by onekk »
Did you see the wiki page about Loft?
There are some technical details to make a correct loft.
As example the two profiles must have same number of segments.
and if they bend the angle must no be too sharp, eventually add an itermediate profile (with same edges count) to guide the bend.
Usually for a non complicated loft it will work on most cases.
Regards.
Carlo D.
- Various other stuffs.
grandcross
You sir are a magician!
I was making a single spline for the airfoil. By splitting it into two separate splines of a half airfoil each, the loft had enough reference points to generate a proper shape. Thanks!
onekk
Post by onekk »
grandcross wrote: Fri Sep 30, 2022 12:24 pm You sir are a magician!
You are welcome!
It not black magic, it is simply the count of error made, renamed experience. :D
Regards
Carlo D.
onekk wrote: Fri Sep 30, 2022 9:28 am As example the two profiles must have same number of segments.
For completeness sake: this is not a must, but it is recommended for better control, and as seen here: it helps.
grandcross
chrisb wrote: Fri Sep 30, 2022 9:38 pm
That's not entirely true here. Both had the same number of segments already: one. Even adding intermediate chords had no effect. Splitting the chords into two just gave it more reference points to use for lofting.
onekk
Post by onekk »
grandcross wrote: Sat Oct 01, 2022 4:40 am That's not entirely true here. Both had the same number of segments already: one. Even adding intermediate chords had no effect. Splitting the chords into two just gave it more reference points to use for lofting.
I have tested first file with my 0.20.1 Linux version:
OS: Artix Linux (openbox)
Version: 0.20.1.29410 (Git) AppImage
Branch: (HEAD detached at 0.20.1)
Hash: f5d13554ecc7a456fb6e970568ae5c74ba727563
Locale: Italian/Italy (it_IT)
Installed mods:
  * Assembly4 0.12.4
  * toSketch 1.0.1
  * Curves 0.5.8
And it works, even with the bsplines with a single segment.
Regards
Carlo D.
onekk
Post by onekk »
Thanks for pointing out this fact.
In fact testing the first file as told in my preceding post it works, without errors, but I don't see differences in OCCT version so I have some doubt what is causing the error in the OP installation.
Regards
Carlo D.
