[tracker] bugs in the toponaming branch
Report observations made with the new Toponaming branch.
uwestoehr
Post by uwestoehr »
This thread is to collect bugs and flaws you find in the toponaming branch, see its announcement:
https://forum.freecadweb.org/viewtopic.php?f=10&t=73017
Please report every issue in a separate post to this thread.
To keep the overview, this post will get a list of reported issues and their status (as we e.g. did for the TD development: https://forum.freecadweb.org/viewtopic. ... 15#p366615).
drmacro
Re: [tracker] bugs in the toponaming branch
Post by drmacro »
It was suggested to mention this Part TNP discussion: https://forum.freecadweb.org/viewtopic. ... 91#p636291
uwestoehr
Post by uwestoehr »
drmacro wrote: Sat Oct 29, 2022 11:39 am It was suggested to mention this Part TNP discussion: https://forum.freecadweb.org/viewtopic. ... 91#p636291
Thanks.
Since this thread is to collect particular bugs, can you please describe the bug you found in a new post in a way that it can be reproduced to be fixed?
For info: I mad now the announcement of the first toponaming build:
Please use this build for testing and bug reports (this assures that everybody uses the same code base).
drmacro
Post by drmacro »
Select Part workbench.
Create a sketch, create a rectangle.
Close the sketch.
Extrude the sketch.
Select the top face.
Close the sketch.
Extrude the sketch
Select both extruded
Boolean union
Open the first sketch, add a hole, close the sketch
Second extrudecis now on the bottom face of first extrude.
See video in previously linked post.
drmacro
Post by drmacro »
uwestoehr wrote: Sun Oct 30, 2022 12:19 am
Thanks.
I don't use conda or appimage.
The version I used is built daily from the topo branch on github.
wsteffe
Post by wsteffe »
I have reproduced this bug using freecad snap (--channel=latest/edge/toponaming).
My result is even more wired because also the x,y position changes after adding a hole to the first sketch:
Nsikak1
Post by Nsikak1 »
wsteffe wrote: Sun Oct 30, 2022 7:16 am
The Bug doesn't exist on linkstage3
drmacro
Post by drmacro »
Nsikak1 wrote: Mon Oct 31, 2022 11:12 am
Really, now there's a surprise... ;)
wsteffe
Post by wsteffe »
drmacro wrote: Mon Oct 31, 2022 12:29 pm The Bug doesn't exist on linkstage3
Yes I have also seen that this problem doesn't happen with LinkDaily.
To be more precise in both cases (TopoNaming-v1 and LinkDaily) the face name switches from Extrude-face6 to Extrude-face7 when the circle (hole) is added to first sketch.
The difference is that in LinkDaily the support of the second sketch is updated accordingly while in TopoNaming-v1 it is not and it keeps pointing to Extrude-face6.
drmacro
Post by drmacro »
wsteffe wrote: Mon Oct 31, 2022 1:19 pm
Nope, I did not say that, Nsikak1 said that. I said it in a different thread.
Nsikak1 wrote: Mon Oct 31, 2022 11:12 am ...
