[done] FreeCAD 0.20.2 release by the end of November
Since FreeCAD 0.20.1 we could fix several bugs making it worth a new release.
The plan would be by the end of the November. Are there any objections?
@all developers, can you please check your recent merged commits and report which ones could be backported to the 0-20 branch? Please either backport directly or tell me in this thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=69437
what commits I should backport.
many thanks in advance and regards
Uwe
Uwe
Re: FreeCAD 0.20.2 release by the end of November
Thanks, @uwestoehr, I think that's a good idea. I believe I am up-to-date on my backports list. FYI next week is a holiday week in the US, so some developers may not be as available as usual towards the end of the week.
@looo , please give it a try to make builds from the 0.20.2 tag of the 0-20 branch.uwestoehr wrote: ↑Mon Dec 05, 2022 2:27 am Here we are: https://github.com/FreeCAD/FreeCAD/releases/tag/0.20.2
Re: [done] FreeCAD 0.20.2 release by the end of November
I also released a new LibPack: https://github.com/FreeCAD/FreeCAD-LibP ... es/tag/2.8
No AppImages for Linux with this point release?
- Various other stuffs.
- adrianinsaval
Sorry, my faulty memory. I have not remembered that @looo is responsible to make AppImages.adrianinsaval wrote: ↑Mon Dec 05, 2022 11:24 am ...
you can see two posts above yours that uwe asked looo to make builds
Regards
Carlo D.
Have you tested AddonManager, I cannot get it to load either as a new user or using existing config files, looks to be a SSL issue?uwestoehr wrote: ↑Mon Dec 05, 2022 2:27 am Here we are: https://github.com/FreeCAD/FreeCAD/releases/tag/0.20.2
Before FreeCAD has fully completed it's startup routine there's an error:
21:18:22 During initialization the error "DLL load failed while importing _ssl: The specified module could not be found." occurred in C:\Users\JPS\AppData\Roaming\FreeCAD\Mod\CfdOF\.\InitGui.py
21:18:22 Please look into the log file for further information
and when trying to load AddonManager it gives message box:
Unable to read data from GitHub: check your internet connection and proxy settings and try again
@hammax has also reported this issue so it's not just myself.
OS: Windows 7 Version 6.1 (Build 7601: SP 1)
Version: 0.20.2.29601 (Git)
Branch: releases/FreeCAD-0-20
Hash: aaee1b5e3934a13b05028f6b2d19157732f47be8
Python 3.8.10, Qt 5.15.2, Coin 4.0.1, Vtk 8.2.0, OCC 7.6.3
Installed mods:
* A2plus 0.4.56a
* Assembly3 0.11.3
* CfdOF 1.17.7
* Curves 0.5.4
* fasteners 0.3.51
* fcgear 1.0.0
* freecad.xray 2022.4.17
* Help 1.0.3
* Manipulator 1.4.9
* Plot 2022.4.17
* sheetmetal 0.2.57
* Silk 1.0.0
* timber
Many thanks for testing!
One of the new things in this release is the upgrade to OpenSSL 3.0.7, see this thread:
https://forum.freecadweb.org/viewtopic.php?p=639511
I tested the addon manager and I can install, uninstall and update packages.
Only after running an update when FC asks me to restart I get now this error:
23:45:36 Traceback (most recent call last):
23:45:36 File "C:\Users\USti\AppData\Local\Programs\FreeCAD 0.20\Mod\AddonManager\AddonManager.py", line 1378, in update_all
23:45:36 functools.partial (self.subupdates_succeeded.append, repo)
23:45:36 NameError: name 'repo' is not defined
