1. Does it compile under Windows? I have only tested it under Kubuntu 14.04
I tested the new branch today evening and there were a couple of things to fix on Windows. Attached is a patch file (remove the .zip extension)
2. Is the behavior the same as with the old viewer? The only notable difference should be that the anti-aliasing settings can not be switch on the fly anymore but requires a reopening of the viewer.
What is the reason that this cannot be done directly? SoQt actually also only uses Qt stuff and there it is possible.
There are no additional features implemented yet compared to current master. This is just to get the porting going.
I appreciate this very much!!! Unfortunately, we sometimes have patches or merge requests which does by far more than the promised fix and this makes the code review unnecessarily complicated.
After it built successfully I played a little bit. Here my observations:
* for Part shapes there is always a face with some light-blueish colour which you cannot get rid of. That looks a bit strange to me
I finished the porting of freecads View3DInventorViewer to a custom quarter based implementation. Before making a pull request I would like to here some opinions, as the internal changes are rather big. It would be fantastic if someone could test the following:
Can we have a test phase of a few weeks to see if it causes some major or minor problems? The recent big merge now appeared to be a middle disaster because it broke FreeCAD on many systems and I don't want to have this a second time. Then we should fix all these little things Mark has already reported.
Unfortunately, from Monday on I will be off for two weeks (maybe I have rarely time to visit the forum) but won't be able to work (a lot) on FreeCAD. So, I would appreciate it if we could do the merge when I am back.
