how to check in C++ for a Python-defined object
uwestoehr
Post by uwestoehr »
I need to check if a selected object has a certain Type. How is this done for Python Objects?
Usually I can either use
getSelection().getObjectsOfType<Type>
or I get from the SelectionSingleton the App:DocumentObject and then
object->getTypeId().isDerivedFrom(Base::Type::fromName("Typename"))
My case is that Type/Typename is a Python-defined object. What would be its Typename?
uwestoehr
Re: how to check in C++ for a Python-defined object
Post by uwestoehr »
uwestoehr wrote: Wed Feb 01, 2023 4:52 am My case is that Type/Typename is a Python-defined object. What would be its Typename?
I tried now this:
object->getTypeId().getName()
But this does not give me a unique string to check what type it actually is. In my case I need to check if it is a FEM Elmer solver object.
The result is always FEM::FEMSolverObjectPython, no matter if it is a Ccx, Z88 or Elmer solver object.
Roy_043
Post by Roy_043 »
In Python you can check the class:
obj.Proxy.__class__
uwestoehr
Post by uwestoehr »
Roy_043 wrote: Wed Feb 01, 2023 8:49 am In Python you can check the class:
obj.Proxy.__class__
Thanks. How can I call this from C++ to evaluate the result?
Roy_043
Post by Roy_043 »
I do not know C++. Searching the source code shows that DlgPropertyLink.cpp may provide the answer.
