Drawing dimensioning workbench for FreeCAD v0.15
Re: Drawing dimensioning workbench for FreeCAD v0.15
Has anyone else noticed a bug with the Escape Dimensioning function? I just made not of it in the github repo, but was wondering if it's just me or are others seeing it.
Steps to reproduce -
Create a dimension. Start to create a second dimension and escape it using the Escape Dimensioning function. Add a new dimension. Attempting to add the new dimension after the Esc function produces an error and no further dimensions can be added without closing FreeCAD and restarting the session.
Mark
OS: Kubuntu 14.04.1 LTS
Version: 0.15.4484 (Git)
Hash: f72c802f5daa378298ffbfc3f3a17ec2d35c1816
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17-dev
Mark
Qt version: 4.8.6
I get the same thing in
OS: Windows 7
Version: 0.15.4435 (Git)
Hash: f24e216db4fb923b2571ad9d856f934e81bec797
Python version: 2.7.8
Qt version: 4.8.6
OCC version: 6.7.1
I made a fresh pull from Hammish's Git Repo before I tried it.
If I use the ESC key instead of the ESC Dimensioning Tool It works as expected.
After using the ESC Dimensioning tool. If I try a second time to add a dimension after the first unsuccessful attempt the vertices are shifted but I still cannot add a dimension.
OS: Windows 7
Qt version: 4.8.6
OCC version: 6.7.1
"fight the good fight"
I get the same.
OS: "Arch Linux"
Version: 0.15.4470 (Git)
Hash: 5289967304b7ab467e264e41386234f218812cbf
Python version: 2.7.9
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.7.1
OS: "Arch Linux"
Qt version: 4.8.6
Coin version: 3.1.3
OCC version: 6.7.1
Thanks guys, good to know it's not just me.
In the mean time, a big thanks to crobar for the notation indicator. Working as expected. And a continued thanks to hamish for making this plugin available.
Mark
Mark
- microelly2
there are already some bugs reported in the git
https://github.com/hamish2014/FreeCAD_d ... ing/issues
I think it makes sense to collect the information there, its easier to have all on one place.
I have seen the missplacement of the green dots in the case of drawing center lines
and sometimes the complete freecad crashes when I draw the second or third line.
Hi , I use last version loaded yesterday. I can't reproduce that , for me it's Ok for the time.. Great job! I planed to do it but hamish has already done it , Assembly2 is great too ! Thanks for all! now we just need suface workbench
OS: "Mageia 4"
Version: 0.15.4514 (Git)
Hash: 378deaf7a3481ff35135079745bd37edf8c228b2
Qt version: 4.8.6
OCC version: 6.7.1.oce-0.16
Hi everybody,
first of all, thank you very much for sharing such a good software. I am using it regularly to do fast prototyping in my R&D work. Usually I don't have problem, but I wanted to try the dimensioning workbench. I follow the instruction but I get an error when I select the workbench.
I usually don't have problem to follow the installation instruction, bur I am far to be a code developer and I couldn't fix it by myself.
Some precision:
OS: Windows XP
Word size of OS: 32-bit
Word size of FreeCAD: 32-bit
Version: 0.15.4527 (Git)
Hash: 0da2e4c45a9a259c26abd54c2a35393e1c15696f
Qt version: 4.8.6
OCC version: 6.7.1
Moreover, I don't have administrator right and I cannot do anything for that, the administrator of the company being not flexible at all.
I would be glad if I can have some help to fix that.
Thanks!
PS: by the way, I have exactly the same error with the Assembly2 workbench
DLL load failed: No se pudo iniciar la aplicaci�n porque su configuraci�n es incorrecta. Reinstalar la aplicaci�n puede solucionar el problema.
File "<string>", line 5, in Initialize
File "D:\Test\FreeCAD_0.15.4527_x86_WinXP_dev_bin\Mod\assembly2\assembly2lib.py", line 11, in <module>
import numpy, os
File "D:\Test\FreeCAD_0.15.4527_x86_WinXP_dev_bin\bin\lib\site-packages\numpy\__init__.py", line 170, in <module>
from . import add_newdocs
File "D:\Test\FreeCAD_0.15.4527_x86_WinXP_dev_bin\bin\lib\site-packages\numpy\add_newdocs.py", line 13, in <module>
from numpy.lib import add_newdoc
File "D:\Test\FreeCAD_0.15.4527_x86_WinXP_dev_bin\bin\lib\site-packages\numpy\lib\__init__.py", line 8, in <module>
from .type_check import *
File "D:\Test\FreeCAD_0.15.4527_x86_WinXP_dev_bin\bin\lib\site-packages\numpy\lib\type_check.py", line 11, in <module>
import numpy.core.numeric as _nx
File "D:\Test\FreeCAD_0.15.4527_x86_WinXP_dev_bin\bin\lib\site-packages\numpy\core\__init__.py", line 6, in <module>
from . import multiarray
Some precision:
OS: Windows XP
Qt version: 4.8.6
OCC version: 6.7.1
Thanks!
MS has dropped support for Winxp some time ago....hence no more security updates. You really should not be using it any more, particularly on a machine connected to the Internet.
The cheapest and easiest solution is to just install a Ubuntu Linux LTS version (currently 14.04) or a popular Ubuntu variant like Kubuntu (uses KDE for the GUI).
It is my work computer... and I know very well that MS stopped the support for WinXP... I don't have choice .
I could install it on my personal computer but I already spend to much time at work and I don't want to put "work related things" on my home computer... home time is for the family, not to do CAD .
I hope hope somebody can help me to find a solution... even if it is to deal with WinXP...
this seems like a numpy problem. To verify please type this into your python console:
If this also fails you need to check how you installed numpy (it does not come with freecad). You need to make sure you installed a numpy version which was build for the same python version as freecad. For example numpy for python 3 will crash when loaded from python 2.7 in your Freecad version
import numpy
