Assembly 2 workbench for FreeCAD v0.15
bernd
Re: Assembly 2 workbench for FreeCAD v0.15
Postby bernd » Thu Apr 30, 2015 10:26 am
NormandC wrote:... Install the freecad-extras-XXX ...
Is there a list somewhere of all available freecad-extras ?
microelly2
Postby microelly2 » Thu Apr 30, 2015 10:55 am
bernd wrote:Is there a list somewhere of all available freecad-extras ?
I have started my list here with my favorites
https://github.com/microelly2/freecad-p ... onfig.yaml
this is the state of my install tool:
viewtopic.php?f=8&t=10556&start=10#p86525
Site Admin
Postby wmayer » Thu Apr 30, 2015 11:27 am
It seems that current only assembly2 is packaged: https://launchpad.net/~freecad-communit ... ubuntu/ppa but the drawing-dimension module is already in work https://code.launchpad.net/~freecad-community
NormandC
Postby NormandC » Thu Apr 30, 2015 12:06 pm
I thought from my post it was clear Assembly2 was the first packaged module, hence the only one ATM...
The topic I linked contains the list of modules I intend to make packages of in the first post. But this is off topic here...
EDIT: I intend to create a wiki page about the FreeCAD Extras, I just haven't had the time yet.
Reason: More info about intended modules and wiki page
bernd
Postby bernd » Fri May 01, 2015 10:59 am
thanks for the informations.
Mhh sorry for highjacking and @norm sorry for not reading carefully your post.
confrey
Postby confrey » Tue May 05, 2015 8:18 am
Hi people, here what I need help for : while trying to assembly a bit complex model, I do separate files of single assembly modules, to get them assembled together into a single 'assembly' file using join project feature; but, for example, if I assembly three parts into a first assembly file, then other three parts into a second assembly file, then, after joining the two files, I can't create constraints anymore, getting always a solver error; but if I proceed into the first assembly files, adding a fourth and so on parts all goes fine; I can work so, but it's not a good way to work, it'd be more simply to create single small assembly files and then connecting them together with few constraints instead of having a big assembly growing up file; besides, it'd be very fine having hightlighting of selected face in assembly, for example, after creating a constraints, if I select a constraint face in properties box I can see that face highlighted in 3d view, is it possible?
and what about trying to solve manually the solver error?
thanks everybody
(I'll post this on G+ too)
sgrogan
Postby sgrogan » Tue May 05, 2015 11:22 am
confrey
Postby confrey » Tue May 05, 2015 12:55 pm
many thanks, but I didn't understand very well how todo, a YT video will be perfect....
grantox
Assembly2 and problems with constrains?
Postby grantox » Wed May 13, 2015 6:29 pm
Hello Community,
short while ago i downloaded FreeCAD 0.15 stable first on Linux,
yesterday also on Win-XP on my Job-Machine.
But i have some strange things, i may need some help.
OS: Ubuntu 14.04.2 LTS
Version: 0.15.4671 (Git)
Branch: releases/FreeCAD-0-15
Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
This is my main machine w. FreeCAD.
Now, i uploaded a video clip, about my troubles and hope someone can give advise,
where i may doing things wrong with Assembly2.
The Video is here: https://vid.me/cPrp
Just 7mins and a bit.
When i try to assemble my first set of parts, all works fine,
then trying to put together the second set, i can not use constrains,
unless i delete all previous once from my first set.
At the end of the thread i will also upload the parts.
I just dont know where i am going the wrong way that i can not get it all constrained.
Thank you for advise,
Regards
Grantox
Adaptr.fcstd
(6.64 KiB) Downloaded 28 times
Flange_plate.fcstd
(5.38 KiB) Downloaded 26 times
Base_plate-002.fcstd
(6.86 KiB) Downloaded 26 times
Base_plate-01.fcstd
(8.65 KiB) Downloaded 25 times
NormandC
Re: Assembly2 and problems with constrains?
Postby NormandC » Wed May 13, 2015 7:04 pm
Hello grantox,
The Assembly2 workbench is a community plug-in that has nothing to do with the "Assembly" native workbench that is being worked on. Which is why I moved your post from the "Assembly" developer forum to the appropriate topic.
