Sketcher: Bezier curves
abdullah
Re: Sketcher: Bezier curves
Postby abdullah » Mon Apr 10, 2017 8:13 pm
wmayer wrote:All good now. Thanks for your quick fixes and awesome contributions!
You are welcome. It is a privilege to work with you.
Site Admin
Postby wmayer » Tue Apr 11, 2017 12:40 pm
A new coverity scan found this issue in int Sketch::addConstraint(const Constraint *constraint):
case BSplineControlPoint:
    rtn = addInternalAlignmentBSplineControlPoint(constraint->First,constraint->Second, constraint->InternalAlignmentIndex);
case BSplineKnotPoint:
    rtn = addInternalAlignmentKnotPoint(constraint->First,constraint->Second, constraint->InternalAlignmentIndex);
default:
    break;
Is it intended to omit the break after BSplineControlPoint and BSplineKnotPoint?
abdullah
Postby abdullah » Tue Apr 11, 2017 4:19 pm
wmayer wrote:Is it intended to omit the break after BSplineControlPoint and BSplineKnotPoint?
Not at all. I wonder how things actually work sometimes...
https://github.com/FreeCAD/FreeCAD/pull/688
microelly2
Postby microelly2 » Thu Apr 13, 2017 6:25 am
There is one big feature to improve usability I want to request:
Hide/unhide the blue constraints
I use the blue constraints as driver for more complex sketches
and for a "free" curve design the sketcher can be used but the data should be hidden.
https://www.youtube.com/watch?v=J4kD1LLP3uU
Thanks in advance
abdullah
Postby abdullah » Thu Apr 13, 2017 12:11 pm
microelly2 wrote:There is one big feature to improve usability I want to request:
Thanks in advance
So you use driven constraints as reference constraints for bspline parameter computation. Nice!!
In my list of sketch usability improvements there is inter alia:
1. hiding construction geometry from the inventor view
2. allowing to filter in the Elements Widget by construction yes, construction no, only construction (not clear yet how I want to put this in the UI)
3. hiding internal alignment constraints from the Constraint's Widget
so I add to it:
4. hiding driven constraints in the inventor view.
Feel free to speak up if you see any other usability improvement ;)
abdullah
Postby abdullah » Tue Apr 18, 2017 12:26 am
Thanks in advance
https://forum.freecadweb.org/viewtopic. ... 04#p170204
Pull Request:
https://github.com/FreeCAD/FreeCAD/pull/696
NormandC
Postby NormandC » Wed Apr 19, 2017 2:36 am
abdullah, you are on fire! :D
abdullah
Postby abdullah » Thu Apr 20, 2017 9:17 pm
It is good to have time to code. It feels good!
Postby Kunda1 » Wed Apr 26, 2017 1:32 pm
Soft segway: Just a little historical context: The history of Bézier curves
microelly2
Postby microelly2 » Wed Apr 26, 2017 3:15 pm
Kunda1 wrote:Soft segway: Just a little historical context: The history of Bézier curves
nice paper with a lot of interesting things.
