Well motivated mathematical insights combined with interactive graphics. Very interesting, indeed.Kunda1 wrote:Soft segway: Just a little historical context: The history of Bézier curves
Untested, no access to FreeCAD ATM (I just copy the code from Github c++ and give you a link on how to use that info):microelly2 wrote: ↑Fri Apr 06, 2018 7:57 pmIs there a way to execute the Sketcher BSpline Tools "Show/Hide XYZ" commands by a python method?
You are just amazing! Am I wrong that you posted another video to G+ which had the typical levers of Bezièrs like the ones of inkscape?microelly2 wrote: ↑Fri Apr 20, 2018 1:58 pmbecause Bezier curves are easier to place than BSplines here a demo how a Bezier can work.
Endpoints of the Bezier Curves can be places exact using common Sketcher constraints
tangent direction and force is done by tangent helper points.
That would be really great to have the inkscape like handles. Currently I prefer to edit Beziers in inkscape and import them to FreeCADabdullah wrote: ↑Sat Apr 21, 2018 9:59 amAm I wrong that you posted another video to G+ which had the typical levers of Bezièrs like the ones of inkscape?
When coding the current B-Spline functionality, I did thought of creating more tools to handle these curves. Eventually I will give it another go to B-Splines.
That will be possible
# -*- coding: utf-8 -*-
#-- create a sketch for a closed bezier curves chain
#-- microelly 2018 0.1
#-- GNU Lesser General Public License (LGPL)
import FreeCAD,FreeCADGui,Sketcher,Part
App = FreeCAD
Gui = FreeCADGui
import numpy as np
import time
import random
class FeaturePython:
''' basic defs'''
def __init__(self, obj):
obj.Proxy = self
self.Object = obj
def attach(self, vobj):
self.Object = vobj.Object
def claimChildren(self):
return self.Object.Group
def __getstate__(self):
return None
def __setstate__(self, state):
return None
class ViewProvider:
''' basic defs '''
obj.Proxy = self
self.Object = obj
return None
return None
def setupContextMenu(self, obj, menu):
menu.clear()
action = menu.addAction("MyMethod #1")
action.triggered.connect(lambda:self.methodA(obj.Object))
action = menu.addAction("MyMethod #2")
menu.addSeparator()
action.triggered.connect(lambda:self.methodB(obj.Object))
action = menu.addAction("Edit Sketch")
action.triggered.connect(lambda:self.myedit(obj.Object))
def myedit(self,obj):
self.methodB(None)
Gui.activeDocument().setEdit(obj.Name)
obj.ViewObject.show()
self.methodA(None)
def methodA(self,obj):
print "my Method A"
FreeCAD.activeDocument().recompute()
def methodB(self,obj):
print "my method B"
def methodC(self,obj):
print "my method C"
def unsetEdit(self,vobj,mode=0):
self.methodC(None)
def doubleClicked(self,vobj):
print "double clicked"
self.myedit(vobj.Object)
print "Ende double clicked"
def getNamedConstraint(sketch,name):
'''get the index of a constraint name'''
for i,c in enumerate (sketch.Constraints):
if c.Name==name: return i
print ('Constraint name "'+name+'" not in ' +sketch.Label)
raise Exception ('Constraint name "'+name+'" not in ' + sketch.Label)
def clearReportView(name):
from PySide import QtGui
mw=Gui.getMainWindow()
r=mw.findChild(QtGui.QTextEdit, "Report view")
r.clear()
import time
now = time.ctime(int(time.time()))
App.Console.PrintWarning("Cleared Report view " +str(now)+" by " + name+"\n")
##\endcond
class BezierSketch(FeaturePython):
'''Sketch Object with Python for Bezier Curve'''
##\cond
def __init__(self, obj, icon='/home/thomas/.FreeCAD/Mod/freecad-nurbs/icons/draw.svg'):
obj.Proxy = self
self.Type = self.__class__.__name__
self.obj2 = obj
self.aa = None
obj.addProperty("App::PropertyInteger",'polescount',).polescount=12
obj.addProperty("App::PropertyBool",'init')
ViewProvider(obj.ViewObject)
##\endcond
def execute(proxy,obj):
obj.Shape=run(obj)
def run(sk):
gc=sk.GeometryCount
ap=gc/3
print ("geometry count, poles, constraints count",gc,ap,sk.ConstraintCount)
try:
if sk.init:
if sk.ConstraintCount <= 150:
for i in range(ap-1):
rc=sk.addConstraint(Sketcher.Constraint('Parallel',3*i+3,3*i+2))
# sk.setVirtualSpace(rc, True)
sk.solve()
rc=sk.addConstraint(Sketcher.Constraint('Parallel',gc-1,0))
sk.init=False
for i in range(90):
# must become parameteric, depends on the number sk.polescount
#if i in [2,3,8,9,15,16,]: # for 3
# if i in [0,1,6,7,13,14,19,20]: # for 5
if i in [0,1, 6,7, 13,14, 20,21, 27,28, 34,35, 41,42, 47,48 ]: # for 7
sk.setDriving(i,False)
sk.setVirtualSpace(i, True)
jj=sk.addConstraint(Sketcher.Constraint('Distance',0,10))
sk.setDriving(jj,False)
sk.setVirtualSpace(jj, True)
jj=sk.addConstraint(Sketcher.Constraint('Distance',20,10))
print "done"
except: pass
# for c in range(sk.ConstraintCount):
# sk.setVirtualSpace(c, True)
try:
#poles=[ sk.getPoint(i,1) +FreeCAD.Vector(0,0,random.random()*2000) for i in range(sk.polescount)]
#poles=[ sk.getPoint(i,1) +FreeCAD.Vector(0,0,0) for i in range(sk.polescount*3)]
# gleich doppelte Punkte
poles=[]
for i in range(sk.polescount*3):
p=sk.getPoint(i,1)
if i%3== 0:
poles += [p,p,p] # corner pole -- multiplicity 3
else:
poles += [p] # tangent pole
cc=Part.BSplineCurve(poles+[poles[0]])
return cc.toShape()
except:
return Part.Shape()
def init_bezierring(sk,count=5,source=None):
if source <> None:
ptsa=source.Shape.Wires[0].discretize(count*2*10)
ptsb=[]
# read some exact point p for the pole and a approx tangent p2-p, pv-p for the tangent indicators
for n in range(count):
p=ptsa[2*n*10]
p2=p+ (ptsa[2*n*10+1]-p).normalize()*10
pv=p+((p-p2).normalize())*(10)
if n==0:
last=pv
ptsb += [p,p2]
else:
ptsb += [pv,p,p2]
# the tangent from the first pole
ptsb += [last]
# map from xz scan to xy sketch
pts=[FreeCAD.Vector(p.x,p.z,0) for p in ptsb]
else: # a generated circle with some noise
r=100
pts=[]
for i in range(count):
p=FreeCAD.Vector(r*np.cos(2*i*np.pi/count),r*np.sin(2*i*np.pi/count),0)
p2=FreeCAD.Vector(r*np.cos((2*i+1)*np.pi/count),r*np.sin((2*i+1)*np.pi/count),0)
p2 += FreeCAD.Vector((0.5-random.random())*0.2*r,(0.5-random.random())*0.2*r)
pm=(p+p2)*0.5
pts +=[p,pm,p2]
if i <> 0: # connect to the last segment with a connector line
lc=sk.addGeometry(Part.LineSegment(pts[3*i-1],pts[3*i]),False)
sk.addConstraint(Sketcher.Constraint('Coincident',lb,2,lc,1))
la=sk.addGeometry(Part.LineSegment(pts[3*i],pts[3*i+1]),False)
lb=sk.addGeometry(Part.LineSegment(pts[3*i+1],pts[3*i+2]),False)
if 1: # avoid moving of points
p2=sk.getPoint(lb,1)
cc=sk.addConstraint(Sketcher.Constraint('DistanceX',lb,1,p2.x))
sk.addConstraint(Sketcher.Constraint('DistanceY',lb,1,p2.y))
sk.renameConstraint(cc, u'aa ' + str(i))
p2=sk.getPoint(la,1)
cc=sk.addConstraint(Sketcher.Constraint('DistanceX',la,1,p2.x))
sk.addConstraint(Sketcher.Constraint('DistanceY',la,1,p2.y))
sk.renameConstraint(cc, u'bb ' + str(i))
# blocking does not work (unsolvable by sketcher) why?
# sk.addConstraint(Sketcher.Constraint('Block',lb))
sk.addConstraint(Sketcher.Constraint('Coincident',la,2,lb,1))
if i <> 0: # connect connector line to the new created segment
sk.addConstraint(Sketcher.Constraint('Coincident',lc,2,la,1))
# close the figure
# the last connector
la=sk.addGeometry(Part.LineSegment(pts[3*i],pts[0]),False)
sk.renameConstraint(cc, u'cc ' + str(i))
# connect head and foot
sk.addConstraint(Sketcher.Constraint('Coincident',lb,2,la,1))
sk.addConstraint(Sketcher.Constraint('Coincident',la,2,0,1))
def createBezierSketch(name="BezierRing",source=None):
if source <> None:
name="Sk_"+source.Label+'_'
obj = FreeCAD.ActiveDocument.addObject("Sketcher::SketchObjectPython",name)
BezierSketch(obj)
obj.polescount=7
init_bezierring(obj,count=obj.polescount,source=source)
obj.init=True
return obj
def createBezierRingSketch(name="BezierRing",source=None):
return createBezierSketch(name,source)
if __name__ == '__main__':
createBezierRingSketch()
