Sketcher: Bezier curves
Jee-Bee
Re: Sketcher: Bezier curves
Postby Jee-Bee » Wed Nov 14, 2018 10:25 am
I checked you're videos a bit better...
Indeed the curve goes thru the line but the Bezier line don't go thru all points but only the middle/ end one. The others are still control lines.
As see in my picture a few post back the curve goes thru all points and the control points follow.
microelly2
Postby microelly2 » Wed Nov 14, 2018 11:43 am
If you want to controll not only the points but the tangent forces too you will need extra points. These are usualy the tangent indicators for beziers
here in inkscape:
If you do not want to use these points you have to make some assumptions on the behaviour of the curve.
Here is an example where I calculate a minimum length bezier on top of a polygon of control points. I use scipy
https://youtu.be/Uu2qIWcTbVE
This is another algorithm which creates useful beziers. The tangents are calculated on base of the neighbour poles.
https://youtu.be/3YdvTzkImrw
Jee-Bee
Postby Jee-Bee » Wed Nov 14, 2018 11:53 am
I guess Creo is doing something similar... Thanks
microelly2
Postby microelly2 » Wed Nov 14, 2018 11:56 am
Would be interesting to know the secret algorithms of the Professional CAD systems.
