shadows in the freecad viewport
Site Admin
Re: shadows in the freecad viewport
Postby wmayer » Sun Jul 21, 2019 9:51 pm
File "/run/media/paullee/Home_1/paullee/Downloads/FreeCAD_0.19-17360-Linux-Conda_Py3Qt5_glibc2.12-x86_64/squashfs-root/usr/Mod/Arch/OfflineRenderingUtils.py", line 7 <!DOCTYPE html>
It looks like the file was downloaded from GH via browser and instead of the raw version the HTML page was downloaded.
paullee
Postby paullee » Mon Jul 22, 2019 12:15 am
Thanks @werner for the hints - I put in the wrongly downloaded file
Putting back the correct file, it works as indicated :D
Screenshot from 2019-07-22 08-11-59.png (173.52 KiB) Viewed 1030 times
pablogil
Postby pablogil » Mon Jul 22, 2019 3:41 pm
I'm just curious: this works only for BIM projects or any body or part element inside FreeCAD could get the shadows?
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
yorik
Site Admin
Postby yorik » Wed Jul 24, 2019 5:29 pm
Anything. Even meshes, and even wireframes seem to work too!
pablogil
Postby pablogil » Fri Jul 26, 2019 10:42 pm
Working flawlessly here in macOS, it's pretty cool.
How about adding it as a new type of shading? I wish I could load-unload it when I want :D
mlampert
Postby mlampert » Sat Jul 27, 2019 12:47 am
prove it! :D
pablogil
Postby pablogil » Sun Jul 28, 2019 8:17 am
Here is the prove but, I have realized that it only works with the fist body I have in the hierarchy and anything else... is this normal?:
Captura de pantalla 2019-07-28 a las 10.15.18.png (96.11 KiB) Viewed 800 times
bitacovir
Postby bitacovir » Sun Jul 28, 2019 7:05 pm
Maybe you need to put the elements into a group like building part.
::bitacovir::
My personal web site
My GitHub repository
My old Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Postby yorik » Mon Jul 29, 2019 2:32 pm
The python snippet that Werner provided above will indeed only grab the first element form the scene. To get them all you need to do this:
from pivy import coin
root = Gui.ActiveDocument.ActiveView.getSceneGraph()
nodes = [node for node in root.getChildren() if isinstance(node, coin.SoSeparator]
newnode = coin.SoSeparator()
for node in nodes:
    newnode.addChild(node) # pack them all into a separator, for convenience
then you use this newnode in your shadowgroup
pablogil
Postby pablogil » Mon Jul 29, 2019 2:46 pm
for node in nodes:
well, I was actually using your code... could you provide mi a full code to try? I have tried several times to inject your new snippet into the main code and I can't make it work...
Thanks
