shadows in the freecad viewport
yorik
Site Admin
Re: shadows in the freecad viewport
Postby yorik » Wed Jul 31, 2019 12:29 am
Basically the main scenegraph is a SoSeparator with a couple of default nodes, and where each view provider inserts another SoSeparator. Since what interests us is the coin nodes created by the view providers, we grab all the SoSeparators inside the main scenegraph node.
And we pack them into a new SoSeparator for convenience. This is the full script:
from pivy import coin
root = Gui.ActiveDocument.ActiveView.getSceneGraph()
nodes = [node for node in root.getChildren() if isinstance(node, coin.SoSeparator]
newnode = coin.SoSeparator()
for node in nodes:
    newnode.addChild(node) # pack them all into a separator, for convenience
import OfflineRenderingUtils
cam = FreeCADGui.ActiveDocument.ActiveView.getCamera() # gather the camera position
rn = OfflineRenderingUtils.embedLight(newnode,(1,1,-1)) # embed the wholescene in a ShadowGroup, add directional light
light = rn.getChild(0) # get a ref to the directional light for later
v = FreeCADGui.createViewer() # create an empty 3D view in FreeCAD
v.setCamera(cam) # set the camera
vv = v.getViewer().setSceneGraph(rn) # set our scene as its scenegraph
light.direction = (-1,-1,-1) # change light direction
pablogil
Postby pablogil » Wed Jul 31, 2019 8:19 am
for node in nodes:
I have fixed a parenthesis in line 3 but I still get this error:
  File ".../shadows_v02.FCMacro", line 9, in <module>
<class 'AttributeError'>: module 'OfflineRenderingUtils' has no attribute 'embedLight'
Any idea?
Dark and Light stylesheets v2.0 to theme your FreeCAD UI, more information here
yorik
Site Admin
Postby yorik » Fri Aug 02, 2019 1:25 pm
This is because you don't have the latest version of this module... Either wait until your FreeCAD package gets updated, or grab from github (in src/Mod/Arch) and replace yours manually...
bitacovir
Postby bitacovir » Mon Aug 05, 2019 12:40 am
I just found this video of a Blender addon with a visual render style for architecture, and it is very similar to what this shadow feature could be. Just wait for the house model in white and with shadows...
phpBB [video]
::bitacovir::
My Blog
Mini Airflow Tunnel Project
yorik
Site Admin
Postby yorik » Mon Aug 05, 2019 11:48 pm
Great!! I still haven't played enough with Blender 2.80...
pablogil
Postby pablogil » Tue Aug 06, 2019 9:01 am
Once updated to the latest version of the module the script works perfectly in macOS:
Captura de pantalla 2019-08-06 a las 10.57.52.png (65.13 KiB) Viewed 298 times
Pretty neat, I wish this can be refined into a workbench or tool so that it can be used as a new mode inside regular FreeCAD :D
Site Admin
Postby wmayer » Wed Aug 07, 2019 8:27 am
In the FreeCAD core system we have the command to render in different draw styles (no shading, wireframe, ...) and we could add it there.
However, at the moment the shadow function is a bit unrealistic because when you move or rotate the model then the shadow follows which means that the light source moves, too. However, the light source should be fix.
I guess this happens because the shadow group appears after the camera node in the scene graph and not before. This must be further checked...
pablogil
Postby pablogil » Wed Aug 07, 2019 9:00 am
Yes, I do agree it may be placed there.
Anyway, here in macOS the light source stays still when rotating so it works as expected.
Apart from that it would be great to get a GUI for tweaking the light position, casting angle, intensity, color and even ambience light intensity and color too =)
yorik
Site Admin
Postby yorik » Sat Aug 10, 2019 1:06 am
I have the impression that there is a kind of default light, somewhere above the camera. If you rotate the scene up to a point that this default light would be close to the directional light defined in the shadow group, then we can see that the shadows gets quite consistent, which would prove the existence of that default light (this seems like astronomy proof :) ) I think I saw something somewhere in the code about such default light already... Maybe it needs to be turned off or kept very dim while using a directional light...
Another two things that need to be solved before adding it as a draw style:
- new view providers added after the mode has been turned on will be added outside the shadowgroup. Means they won't emit or receive shadows. Not sure how that can best be handled...
- We need something so the user can control the light direction and intensity (and maybe color), both with GUI and python access. But I'm going to do that anyway, I'll make sure it can be used FreeCAD-wide..
Site Admin
Postby wmayer » Sat Aug 10, 2019 11:28 am
