homothécie d'une partie de sketch
- freecadjam
Re: homothécie d'une partie de sketch
Ah oui tout simplement, merci. Je confondais encore avec des outils d'un autre atelier. Du coup, je comprends mieux la forme partant au dessus du second sketch.
Bonjour
si vous travaillez avec des lofts (faces) vous pouvez utiliser cette macro:
experiment on destructive subelement modifier
EDIT:26/02/2021 19h53 Paris : correct if coordinate not 0,0,0 add create Single Object, color object same color to face selected
mario
import Draft, Part
import Draft, Part
#https://forum.freecadweb.org/viewtopic.php?f=22&t=46690&sid=18c0765424496ef734ce5b78914f7197
#https://forum.freecadweb.org/viewtopic.php?f=13&t=48276&p=413611#p413611
#https://forum.freecadweb.org/viewtopic.php?f=13&t=48276&p=414467#p414467
#https://forum.freecadweb.org/viewtopic.php?f=22&t=48425
#https://forum.freecadweb.org/viewtopic.php?f=12&t=49299&start=10
# mario52
# 25/05/2020 03/07/2020 07/07/2020 15/07/2020 26/02/2021
selectedEdge = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0] # select one element
SubElementName = FreeCADGui.Selection.getSelectionEx()[0].SubElementNames[0]
sel = FreeCADGui.Selection.getSelection()
try:
colorFace = App.ActiveDocument.getObject(sel[0].Name).ViewObject.DiffuseColor[int(SubElementName[4:])-1] # color face selected
##App.ActiveDocument.getObject(sel[0].Name).ViewObject.DiffuseColor[int(SubElementName[4:])-1] = colorFace# give color on face
except Exception:
colorFace = App.ActiveDocument.getObject(sel[0].Name).ViewObject.DiffuseColor[0] # color face selected [0]
#### configuration ####
ValueLenght = -1000 # value lenght loft if is negatif " - " reverse the loft
ValueScaleX = 1.000 # value scale 1.0 by default
ValueScaleY = 1.000 # value scale 1.0 by default
ValueScaleZ = 1.000 # value scale 1.0 by default
createAxis = 0 # 0 = not Axis, other = Axis
createLoft = 1 # 0 = not loft, other = loft
onlyShape = 1 # if createLoft = 0 : 0 = with all construction, other = single copy
if hasattr(selectedEdge,'Surface'):
plr = plDirection = FreeCAD.Placement()
########## section direction
yL = selectedEdge.CenterOfMass
uv = selectedEdge.Surface.parameter(yL)
nv = selectedEdge.normalAt(uv[0], uv[1])
direction = yL.sub(nv + yL)
r = App.Rotation(App.Vector(0,0,1),direction)
plDirection.Rotation.Q = r.Q
plDirection.Base = yL
plr = plDirection
print( "surface : ", sel[0].Name, " ", SubElementName, " ",colorFace, " ",direction)
########## section axis
if createAxis != 0:
points=[FreeCAD.Vector(0.0,0.0,0.0),FreeCAD.Vector(0.0,0.0,(ValueLenght) )]
centerX = Draft.makeWire(points,closed=False,face=False,support=None)
centerX.Placement = plr
centerX.Label = "Axis_" + SubElementName
#### section scale ####
if createLoft != 0:
Part.show(selectedEdge.copy())
firsFace = App.ActiveDocument.ActiveObject
objClone = Draft.scale(App.ActiveDocument.ActiveObject,App.Vector(ValueScaleX, ValueScaleY, ValueScaleZ),center=App.Vector(plr.Base),copy=True)#False
#### section placement face in length and direction
objClone.Placement.Base = objClone.Placement.Base + App.Vector(direction).scale(ValueLenght, ValueLenght, ValueLenght)
#### section loft
objectLoft = App.activeDocument().addObject('Part::Loft','Loft')
objectLoft.Sections=[App.activeDocument().getObject(firsFace.Name), App.activeDocument().getObject(objClone.Name), ]
objectLoft.Solid = True
objectLoft.ViewObject.DiffuseColor = colorFace
objectLoft.Label = sel[0].Label + "_" + SubElementName
FreeCAD.ActiveDocument.recompute()
#### section loft
#### section hidden faces work
firsFace.ViewObject.Visibility = False
objClone.ViewObject.Visibility = False
#### section single object ####
if onlyShape != 0:
try:
# single object
Part.show(objectLoft.Shape.copy())
App.ActiveDocument.ActiveObject.ViewObject.DiffuseColor = colorFace # give face color on object
App.ActiveDocument.ActiveObject.Label = sel[0].Label + "_" + SubElementName
#### removeObject work
App.ActiveDocument.removeObject(firsFace.Name)
App.ActiveDocument.removeObject(objClone.Name)
App.ActiveDocument.removeObject(objectLoft.Name)
except Exception:
None
mario
- freecadjam
salut, voici trois vues de la pièce reproduite d'après un original
il manquerait à évider le dessous en gardant des paroies de 2 mm, je n'y arrive pas, peut être je devrais procéder avant le substractive pipe inférieur ?
trois captures et le fichier
- 1freecadjam coquille de rembobinage.FCStd
- (633.77 KiB) Downloaded 22 times
