Apres compilation sur Ubuntu10.04, FreeCAD ne démarre pas
YannUbuntu
Postby YannUbuntu » Thu Aug 26, 2010 6:55 am
après avoir compilé (https://sourceforge.net/apps/mediawiki/ ... rmic_Koala), FreeCAD ne démarre pas:
yyy@yyy-laptop:~/freecad/bin$ ./FreeCAD -t 0
FreeCAD 0.11, Libs: 0.11R3419
© Juergen Riegel, Werner Mayer 2001-2010
'str' object is not callable
Détail: la commande "cmake ." me donne ce warning (au mileu des autres lignes):
-- SWIG was not found. Please specify Swig executable location
SWIG was not found, build no SWIG binding for pivy
Je n'ai pas repéré d'autres anomalies durant la compilation.
Site Admin
Re: Apres compilation sur Ubuntu10.04, FreeCAD ne démarre pas
Postby wmayer » Thu Aug 26, 2010 9:09 am
This does some self-tests but doesn't start the application. Just omit the -t 0 parameter and it will work.
Very likely you'll run into problems especially with the Draft module if SWIG is not installed on your system. You're recommended to install the package and rebuild the sources to make sure everything works fine.
