freecadjam
Posts: 1994 Joined: Tue Jul 17, 2018 10:47 am
Post
by freecadjam » Thu Feb 11, 2021 9:39 pm
Salut
l'appimage s'ouvre et se referme après l'affichage du bureau de freecad
le même problème avec les deux versions antérieures
voici le code dans le terminal, votre avis svp
utilisateur1@debian:~/Téléchargements$ ./FreeCAD_0.19-23756-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.19, Libs: 0.19R23756 (Git)
© Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2020
FreeCAD is free and open-source software licensed under the terms of LGPL2+ license.
FreeCAD wouldn't be possible without FreeCAD community.
nouveau: kernel rejected pushbuf: Aucun fichier ou dossier de ce type
nouveau: ch3: krec 0 pushes 0 bufs 1 relocs 0
nouveau: ch3: buf 00000000 00000002 00000004 00000004 00000000
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x37840) [0x7f4cd0415840]
#1 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x31516c) [0x7f4ccab8d16c]
#2 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x315367) [0x7f4ccab8d367]
#3 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x315663) [0x7f4ccab8d663]
#4 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x5a1b90) [0x7f4ccae19b90]
#5 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x5a1be0) [0x7f4ccae19be0]
#6 /tmp/.mount_FreeCAYaQi0K/usr/plugins/designer/../../lib/libQt5QuickWidgets.so.5(+0xaa2f) [0x7f4cb626aa2f]
#7 /tmp/.mount_FreeCAYaQi0K/usr/plugins/designer/../../lib/libQt5QuickWidgets.so.5(+0xaba0) [0x7f4cb626aba0]
#8 0x7f4cd0903533 in QObject::event(QEvent*) from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Core.so.5+0x5b
#9 0x7f4cd114007f in QWidget::event(QEvent*) from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Widgets.so.5+0xcc5
#10 0x7f4cb626d89b in QQuickWidget::event(QEvent*) from /tmp/.mount_FreeCAYaQi0K/usr/plugins/designer/../../lib/libQt5QuickWidgets.so.5+0x387
#11 /tmp/.mount_FreeCAYaQi0K/usr/plugins/designer/../../lib/libQt5WebEngineWidgets.so.5(+0x2b02e) [0x7f4cb5a3b02e]
#12 0x7f4cd11147f2 in QApplicationPrivate::notify_helper(QObject*, QEvent*) from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Widgets.so.5+0xdc
#13 0x7f4cd111a31d in QApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Widgets.so.5+0x1ac9
#14 0x7f4cd2bfc329 in Gui::GUIApplication::notify(QObject*, QEvent*) from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libFreeCADGui.so+0x89
#15 0x7f4cd08ee606 in QCoreApplication::notifyInternal2(QObject*, QEvent*) from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Core.so.5+0x86
#16 0x7f4cd091c8a4 in QTimerInfoList::activateTimers() from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Core.so.5+0x24c
#17 /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Core.so.5(+0x1dbf54) [0x7f4cd091cf54]
#18 /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_dispatch+0x27d) [0x7f4ccd82980d]
#19 /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/./libglib-2.0.so.0(+0x54aa1) [0x7f4ccd829aa1]
#20 /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/./libglib-2.0.so.0(g_main_context_iteration+0x31) [0x7f4ccd829b41]
#21 0x7f4cd091d0e8 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Core.so.5+0x5e
#22 0x7f4cd08eb019 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Core.so.5+0x187
#23 0x7f4cd08eee8f in QCoreApplication::exec() from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libQt5Core.so.5+0xfd
#24 0x7f4cd2b7263a in Gui::Application::runApplication() from /tmp/.mount_FreeCAYaQi0K/usr/bin/../lib/libFreeCADGui.so+0x162a
#25 /tmp/.mount_FreeCAYaQi0K/usr/bin/freecad(+0x37cd) [0x559a8d0417cd]
#26 /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb) [0x7f4cd040209b]
#27 /tmp/.mount_FreeCAYaQi0K/usr/bin/freecad(+0x4559) [0x559a8d042559]
openBrain
Posts: 9031 Joined: Fri Nov 09, 2018 5:38 pm
Post
by openBrain » Thu Feb 11, 2021 10:04 pm
Incompatibilité OpenGL dans le driver Nouveau. Il faudrait regarder sur le forum (notamment anglophone), il doit déjà y avoir des choses.
freecadjam
Post
by freecadjam » Thu Feb 11, 2021 10:11 pm
oui c'est avec un Debian 10 tout neuf monté avec le bureau Mate
openBrain
Post
by openBrain » Fri Feb 12, 2021 7:15 am
Il faudrait tenter d'installer le driver Nvidia à la place du Nouveau (sachant que des fois ça pose d'autres problèmes). Je vais essayer de trouver un lien.
freecadjam
Post
by freecadjam » Fri Feb 12, 2021 12:36 pm
salut
merci pour le coup de main, il s'ouvre normalement à présent
je fais le changement de pilote grâce à la page
https://wiki.debian.org/fr/NvidiaGraphicsDrivers
j'avais aussi ouvert un sujet sur le forum debian xyz
https://www.debian-fr.xyz/viewtopic.php?f=8&t=2114 traitant du choix de version du pilote, en fait de celui qui correspond à la version d'OS. Si l'on ne se trompe pas de version comme je l'ai fait, cette opération se résume à peu de choses et prend cinq minutes. Comme je disais l'OS était tout frais moulu et la question de pilote de carte graphique (toujours problématique) n'avait pas été traîtée comme je l'avais fait avec des installations plus anciennes du matériel
freecadjam
Post
by freecadjam » Fri Feb 19, 2021 1:55 pm
salut
des nouvelles depuis, c'est très cahotique : le programme se ferme à l'enregistrement d'un fichier (il enregistre tout de même), quelques jours plus tard la version 0.19.23964 s'ouvre et se referme dans la foulée. Des mises à jour logicielles du système se sont présentées aujourd'hui et le programme semble bien fonctionner depuis ces mises à jour, pour combien de temps encore ?
Il s'est passé pas mal de temps pour que freecad dernières versions redevienne utilisable dans mon ordinateur, je ne suis pas sûr que chercher à résoudre les problèmes serve à quelque chose, il semble que ce sont les mise à jours de l'OS qui apportent les solutions. Récemment quelqu'un demandait quelle distribution Linux on pouvait lui conseiller, à cet instant je ne me voyais pas conseiller Debian 10, aujourd'hui par contre c'est possible tant que ne se présentent pas de nouveaux problèmes (le post
https://forum.freecadweb.org/viewtopic.php?f=12&t=55549 )
freecadjam on Fri Aug 06, 2021 11:10 am, edited 1 time in total.
freecadjam
Post
by freecadjam » Fri Feb 19, 2021 2:55 pm
voici le terminal lorsque j'ouvre 019.23964 puis quand j'ouvre un fichier récent et lorsque je réouvre car freecad s'est fermé à l'ouverture du fichier récent
utilisateur1@debian:~/Téléchargements$ ./FreeCAD_0.19-23964-Linux-Conda_glibc2.12-x86_64.AppImage
FreeCAD 0.19, Libs: 0.19R23964 (Git)
Line Group File: /tmp/.mount_FreeCAj30QcJ/usr/share/Mod/TechDraw/LineGroup/LineGroup.csv is not readable
/tmp/.mount_FreeCAj30QcJ/AppRun : ligne 41 : 2322 Erreur de segmentation ${MAIN} "$@"
nouveau: ch2: krec 0 pushes 0 bufs 1 relocs 0
nouveau: ch2: buf 00000000 00000002 00000004 00000004 00000000
nouveau: ch2: krec 0 pushes 0 bufs 2 relocs 0
nouveau: ch2: buf 00000001 00000006 00000004 00000000 00000004
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x37840) [0x7f61f6fd5840]
#1 /lib/x86_64-linux-gnu/libdrm_nouveau.so.2(+0x4c9e) [0x7f61f13f0c9e]
#2 /lib/x86_64-linux-gnu/libdrm_nouveau.so.2(+0x5359) [0x7f61f13f1359]
#3 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x307209) [0x7f61f1745209]
#4 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x4b8d63) [0x7f61f18f6d63]
#5 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x47a704) [0x7f61f18b8704]
#6 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x47d0d0) [0x7f61f18bb0d0]
#7 /usr/lib/x86_64-linux-gnu/dri/nouveau_dri.so(+0x480578) [0x7f61f18be578]
#8 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a42934) [0x7f61da6c7934]
#9 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x27fb51b) [0x7f61d948051b]
#10 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x27fb88f) [0x7f61d948088f]
#11 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x27fba12) [0x7f61d9480a12]
#12 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x27f7316) [0x7f61d947c316]
#13 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a72e15) [0x7f61da6f7e15]
#14 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a78e3c) [0x7f61da6fde3c]
#15 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a794f2) [0x7f61da6fe4f2]
#16 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a7b155) [0x7f61da700155]
#17 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a7f715) [0x7f61da704715]
#18 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a7f799) [0x7f61da704799]
#19 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x3a76565) [0x7f61da6fb565]
#20 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1db1330) [0x7f61d8a36330]
#21 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1dd16e1) [0x7f61d8a566e1]
#22 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1dd23ff) [0x7f61d8a573ff]
#23 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1dd257d) [0x7f61d8a5757d]
#24 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1dd0171) [0x7f61d8a55171]
#25 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1df265f) [0x7f61d8a7765f]
#26 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1e255fe) [0x7f61d8aaa5fe]
#27 /tmp/.mount_FreeCAJg1e5I/usr/plugins/designer/../../lib/libQt5WebEngineCore.so.5(+0x1e565af) [0x7f61d8adb5af]
#28 /lib/x86_64-linux-gnu/libpthread.so.0(+0x7fa3) [0x7f61f6e01fa3]
#29 /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f) [0x7f61f70974cf]
flachyjoe
Posts: 1855 Joined: Sat Mar 31, 2012 12:00 pm
Post
by flachyjoe » Fri Feb 19, 2021 4:51 pm
Salut,
freecadjam wrote: ↑ Fri Feb 19, 2021 2:55 pm
Tu utilises encore le pilote Nouveau ?
- Flachy Joe -
freecadjam
Post
by freecadjam » Fri Feb 19, 2021 6:23 pm
voici la réponse du terminal à l'installation du pilote nvidia :
root@debian:/home/utilisateur1# apt install nvidia-driver
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
nvidia-driver est déjà la version la plus récente (460.39-1~bpo10+1).
0 mis à jour, 0 nouvellement installés, 0 à enlever et 0 non mis à jour.
