FEM (débutant)
Almisuifre
FEM (débutant)
Post by Almisuifre »
Bonjour à toutes et tous.
Je suis en train d'essayer le module FEM de la dernière version 0.19.2.
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Locale: French/France (fr_FR)
Lorsque j'essaie de lancer CalculiX, il me retourne une série d'erreur que je ne sais interpréter:
0.0: Check dependencies...
3.8: Write completed.
0.0: CalculiX binary: C:/Program Files/FreeCAD 0.19/bin/ccx.exe
0.0: CalculiX input file: C:\Users\ALEXAN~1\AppData\Local\Temp\fcfem_g14ecxsz\FEMMeshNetgen.inp
0.0: Run CalculiX...
0.0: Starting CalculiX...
0.0: CalculiX is running...
9.3: CalculiX stopped.
9.3: ************************************************************
CalculiX Version 2.17, Copyright(C) 1998-2020 Guido Dhondt
CalculiX comes with ABSOLUTELY NO WARRANTY. This is free
software, and you are welcome to redistribute it under
certain conditions, see gpl.htm
You are using an executable made on Thu Jul 23 21:43:50 CEST 2020
The numbers below are estimated upper bounds
number of:
nodes: 82830
elements: 65314
one-dimensional elements: 0
two-dimensional elements: 0
integration points per element: 4
degrees of freedom per node: 3
layers per element: 1
distributed facial loads: 0
distributed volumetric loads: 0
concentrated loads: 3376
single point constraints: 3378
multiple point constraints: 1
terms in all multiple point constraints: 1
tie constraints: 0
dependent nodes tied by cyclic constraints: 0
dependent nodes in pre-tension constraints: 0
sets: 5
terms in all sets: 330004
materials: 1
constants per material and temperature: 2
temperature points per material: 1
plastic data points per material: 0
orientations: 0
amplitudes: 2
data points in all amplitudes: 2
print requests: 1
transformations: 0
property cards: 0
STEP 1
Static analysis was selected
Decascading the MPC's
Determining the structure of the matrix:
number of equations
245112
number of nonzero lower triangular matrix elements
9604761
Using up to 1 cpu(s) for the stress calculation.
Using up to 1 cpu(s) for the symmetric stiffness/mass contributions.
*ERROR in e_c3d: nonpositive jacobian
determinant in element 10923
determinant in element 10938
determinant in element 10962
determinant in element 10980
determinant in element 54516
determinant in element 59546
9.3: CalculiX execute error:
9.3: Loading result sets...
A priori une série d'élément lui pose problème ors, j'ai bien paramétré ma pièce.
Copie d'écran<br />Copie d'écran
Copie d'écran
Copie d'écran
Configurations
Configurations
Configurations
Configurations
Etude-Piece-2-2.FCStd
La pièce a analyser
(77.63 KiB) Downloaded 26 times
Je cherche une piste car en l'état je ne trouve pas comment résoudre le problème.
Merci
-alex-
Re: FEM (débutant)
Post by -alex- »
Salut à toi,
Almisuifre wrote: Wed Jun 23, 2021 8:57 am *ERROR in e_c3d: nonpositive jacobian
Certains éléments du maillage comportent des erreurs.
Joints à nouveau ton fichier avec l'analyse complète et son maillage (sans les résultats cependant). Sur le maillage clic droit "clear fem Mesh".
Les versions récentes de FreeCAD semblent produire cette erreur avec Netgen. J'ai pu mailler ta pièce sans erreur avec Netgen et une version légèrement antérieure à 0.19.2 sur Windows.
Si tu veux te dépaner rapidement tu peux mailler avec gmsh, et éventuellement affiner la taille du maillage.
Merci de renvoyer ton fichier complet avec maillage Netgen purgé (mais pas supprimé).
Almisuifre
Re: FEM (débutant)
Bonjour,
Merci pour ta réponse.
J'ai trouvé une solution. J'ai décoché "second ordre" et "optimiser". Et là ça fonctionne sans problème.
Ce qui est rassurant c'est que c'est ujn problème récent et que je ne suis pas le seul.
J'ai essayé d'uploader mon fichier avec l'analyse mais "trop lourd" ! Bref, c'étais histoire de faire des essais et d'être au point.
Je continu donc mais je surveille les évolutions sur une 0.19.3 rectifié de ce côté là.
