Spiralbohrer
mario52
Re: Spiralbohrer
Postby mario52 » Sun Jan 22, 2017 1:50 pm
hi
the future version Macro FCSpring create the complete spring with circle
for the moment other forme give (with my method)
the mode point by microelly2 is perfect i study one method ....
freecad-heini-1 wrote:is it possible to change your macro that it snaps the centerpoint of the circle and snaps the endpoint of the helix to orientate the sketch perpendicular to the curve?
If you talk about my little macro
principe :
the line is cut in x points (here Number=500 cuts begin 0 to 499 you can modify)
    pointsDirection = lineSelected.Shape.discretize(Number=500)             # discretize the path line first selection
the perpendicularity is calculate between 2 points modify :
1:
v=pointsDirection[0].sub(pointsDirection[1])          # perpendicular of first > second point
2:
    v=pointsDirection[-1].sub(pointsDirection[-2])       # perpendicular of last > before last point
    pl.Base = pointsDirection[-1]                        # position last point
3:
    v=pointsDirection[100].sub(pointsDirection[101])   # perpendicular of point 100 > point 101
    pl.Base = pointsDirection[100]                     # position point 100
4:
   v=pointsDirection[0].sub(pointsDirection[-1])         # perpendicular of first point > last point
   pl.Base = pointsDirection[0]                          # position first point
for discretize other parameters
#http://forum.freecadweb.org/viewtopic.php?f=12&t=16336#p129468
#Discretizes the edge and returns a list of points.
#The function accepts keywords as argument:
#discretize(Number=n) => gives a list of 'n' equidistant points
#discretize(QuasiNumber=n) => gives a list of 'n' quasi equidistant points (is faster than the method above)
#discretize(Distance=d) => gives a list of equidistant points with distance 'd'
#discretize(Deflection=d) => gives a list of points with a maximum deflection 'd' to the edge
#discretize(QuasiDeflection=d) => gives a list of points with a maximum deflection 'd' to the edge (faster)
#discretize(Angular=a,Curvature=c,[Minimum=m]) => gives a list of points with an angular deflection of 'a'
#and a curvature deflection of 'c'. Optionally a minimum number of points
#can be set which by default is set to 2.
if this macro you is interesting i can create complete gui macro parametrisable
bon weekend
mario
Maybe you need a special feature, go into Macros_recipes and Code_snippets, Dialog creation. My macros on Gist.github.
freecad-heini-1
Re: Spiralbohrer
Postby freecad-heini-1 » Sun Jan 22, 2017 5:26 pm
Thank you very much Mario. I will check this in deep next week.
mario52
Re: Spiralbohrer
Postby mario52 » Sat Apr 08, 2017 10:01 am
hi microelly2
problem with our macros on circle:
y work on my macro "perpendicular to wire" for use with my macro "rotate to point" and i adapt for Best way to convert line drawing image to Freecad file but problem with circle : my macro and your macro
Your macro first circle
My macro second circle
your macro second circle
with pathArray Align = True ( ?? ) first circle
Halphen_00.FCStd
(354.73 KiB) Downloaded 25 times
Your macro replace # h=QtGui.QDial() to h=QtGui.QDoubleSpinBox() and add create copy of triangle on point
# -*- coding: utf-8 -*-
import numpy as np
import Draft
def srun(w):
   bc=w.path.Shape.Edge1.Curve
   c=w.target
   pa=bc.LastParameter
   ps=bc.FirstParameter
   v=w.ha.value()*0.01
   v=ps +(pa-ps)*v
   t=bc.tangent(v)[0]
   p=bc.value(v)
   zarc=np.arctan2(t.y,t.x)
   zarc *=180.0/np.pi
   harc=np.arcsin(t.z)
   harc *=180.0/np.pi
   pl=App.Placement()
   pl.Rotation=App.Rotation(FreeCAD.Vector(0,1,0,),90-harc)
   pa=App.Placement()
   pa.Rotation=App.Rotation(FreeCAD.Vector(0,0,1,),zarc)
   pl2=pa.multiply(pl)
   pl2.Base=p
   c.Placement=pl2
   x = Draft.scale(c,copy=True)
   x.Placement=pl2
from PySide import QtGui, QtCore
def MyDialog(path,target):
   w=QtGui.QWidget()
   w.path=path
   w.target=target
   box = QtGui.QVBoxLayout()
   w.setLayout(box)
   w.setWindowFlags(QtCore.Qt.WindowStaysOnTopHint)
   l=QtGui.QLabel("Position" )
   box.addWidget(l)
#   h=QtGui.QDial()
   h.setMaximum(100)
   h.setMinimum(0)
   w.ha=h
   srun(w)
   h.valueChanged.connect(lambda:srun(w))
   box.addWidget(h)
   w.show()
   return w
def run():
   [path,target]=Gui.Selection.getSelection()
# selektion:
# 1. pfad spline
# 2. zu platzierendes objekt
run()
my macro modified for create triangle along the circle
import Draft, Part
sel = FreeCADGui.Selection.getSelection()                               # Select an object
lineSelected = FreeCADGui.Selection.getSelectionEx()[0].SubObjects[0]   # first object the Path object or SubObjects
myCircle     = sel[1]                                                   # second object
pointsDirection  = []
pointsDirection = lineSelected.discretize(Number=3600)                   # discretize the path line first selection
for i in range(50,3600,50):
    pl = FreeCAD.Placement()
    print i
#    Part.show(myCircle.Shape)                    # create repro shape object
#    Draft.scale(myCircle,delta=App.Vector(1.0, 1.0, 1.0),center=App.Vector(pointsDirection[i]),copy=True,legacy=True)
    Draft.scale(myCircle,copy=True)
    try:
        v=pointsDirection[i-1].sub(pointsDirection[i+1])                            # avec vecteurs 1 et 2 (direction debut ligne)
        r=App.Rotation(App.Vector(0,0,1),v)
    except Exception:
        None
    pl.Rotation.Q = r.Q
    pl.Base = pointsDirection[i]
    App.ActiveDocument.ActiveObject.Placement = pl
del pointsDirection[:]
FreeCAD.ActiveDocument.recompute()
Mario
